TEAM MAGIC 1/8 SHOCK ON-ROAD CAR
The Taem magic 1/8 scale shock on-road car(not gt pro).It has a .21 engine and pipe set and can choose from a VDS lola body or a porshe 962. Is this a good car and would it be capable of beating the other 1/8 scale on-road cars.
It does not come with a radio.
THANKS IN ADVANCE
THANKS IN ADVANCE
i doubt that would be capable of beating the newer kits like the 960, evolve or mrx-4. the shock is an outdated kit.
But if you're on a budget i would suggest getting a used serpent veteq or 950, you can get them fairly cheap IMO. But another thing you should check is if your LHS carries parts for the kit you would like to get
So this car isn't that good
Hi garen..... Im desperately looking for the team magic 1/8 shock gt onroad upper front right arm spares... Do you still have any in your stock
I looked around and did not find any. When we ran the car, we used some prototype front end parts designed by Jason Corl. I recall having the original and Corl parts up until recently, then perhaps throwing them all away finally. Sorry...
You might want to check ebay
http://www.ebay.com/itm/GS-RACING-VI...item564170d28c
Most brands use the same 201 belt, it has 67 teeth. cout them on your old belt if that is the case.
