540 Run In
Old 07-06-2004 | 04:10 AM
  #16
azenis's Avatar
What is shellite and where do you get it?
azenis is offline
Old 07-06-2004 | 04:13 AM
  #17
Timmy_G's Avatar
umm
its clear, flamble, liquid, flamable, and flamable. Sold at hardware stores, and is $3-$5 for a litre.
Timmy_G is offline
Old 07-07-2004 | 01:53 AM
  #18
I don't think they use the name "Shellite"anymore- basically its lighter fluid.
Abu Habib is offline
Old 07-07-2004 | 02:40 AM
  #19
Timmy_G's Avatar
The last time i got it i bought it from Ozzy Disposals, and it was $3.95 a litre n still called shellite as far as i know?
Bunnings sell it too but it's more expensive, $6 I think.
Timmy_G is offline
Old 07-07-2004 | 03:38 AM
  #20
Havago Racing's Avatar
I saw bottles of Shellite for sale on the shelf in Woolworths just last week. (not the liquor section- try auto section, next to the bottled kero and metho)
Havago Racing is offline
Old 07-08-2004 | 03:02 AM
  #21
murfy's Avatar
i i were you guys i would not use this shellite stuff. if you wanted to run-in your 540 motor better drop some lube oil in to the glass of water and if you want to lube the com and brushes just buy som bushing lube from your LHS for about $10 and then you cn also use it on your bearing before each race to keep them smooth.
trust me this method is much easier that frigen' around with the highly flamible shelite stuff.
murfy is offline
Old 07-08-2004 | 03:12 AM
  #22
Ybakoff's Avatar
You have to live with a little danger every now and then.
I also recommend trying to crack onto you girlfriends sister.
More fun than running in 540's
Ybakoff is offline
Old 07-08-2004 | 04:07 AM
  #23
Mr-s413bt's Avatar
HAHAHA, a man after my own heart :P hahaha
Glenn
Mr-s413bt is offline
Old 07-08-2004 | 03:45 PM
  #24
Kennedy's Avatar
From: If Nissan Motorsport is Nismo, Then Honda Motorsport must be Homo
Why are the sisters always SOOOO much HOTTER!!!!!!!!!!!
Kennedy is offline
Old 07-08-2004 | 03:47 PM
  #25
Rod M's Avatar
because you are sooo dam ugly and she is only 14
Rod M is offline
Old 07-08-2004 | 10:29 PM
  #26
Ybakoff's Avatar
Because you know your in deep crap if you try.
It's also fun to try the rodeo with your girl.
Take her doggy stlye. And tell her that her sisters better.
Then see if you can stay on for the 8 seconds.
Ybakoff is offline
Old 07-09-2004 | 02:30 AM
  #27
taj's Avatar
taj
has anyone tried using another motor attached to a 540 through gears or similar to run in said 540 . i mean no electric current would mean no heat from current . i have also heard 1 "sap" saying he "adjusted" the leaf spring tension on the bushes of his 540 gaing more performance. this is ilegal isnt it. and being so how do they scrutineer against such modifications
taj is offline
Old 07-09-2004 | 06:58 AM
  #28
OldSkool's Avatar
I have an old home made jig that we used to run in 540's while putting "braso" on the bushes.
Took to long, the motor in a glass of water ,and tooth paste works best.
As most know tooth paste is like 2000 grit sandpaper, so it grinds away at the bushes, and brushes.
And as far as the bending of the "leaf" brush bending, it does work but it is illegal.
My way for a meet used to be ,run the (new) motor in a glass of water, with about a tea spoon of tooth paste.
About 10 minutes.
Dry off the motor, then spray it out with "BAZ IN A CAN" (now use orion or trinity motor spray) ,let it air dry.
Put a drop of bushing oil on each bushing ,then work the armature up and down ,and spinning.
Put it in the car ,but with a pinoin gear 2 teeth lower than you would normally run, I used to do this for the first 2 runs of the day, because this helps bed the brushes in better ,and also how often does TQ be set in the first 2 heats???
Give it a go, and good luck.
OldSkool is offline
Old 07-09-2004 | 07:40 AM
  #29
Aidz's Avatar
Has anyone acutally tested their methods of run-in on say a dyno or similar, or if they have any links of evidence that these methods work would be nice
Aidz is offline
Old 07-09-2004 | 03:32 PM
  #30
Timmy_G's Avatar
i won the 4wd 540 nationals are canberra in 97.
how's that for evidence?
Timmy_G is offline
