D8Te Grinding in the center diff
I have a d8t that i converted to an electric with the tekno conversion kit, im running the 50/14 gearing and somewhere its got a bad grinding noise when power is applied, the grinding isnt in the motor and doesnt seem to be coming from the center diff, do i just have a bad pinion gear or is something else jacked...any help would be great!
I would check your bearings where the pinion goes into the front and rear diff cases. I would check the rear first. I had an inner bearing go bad and it was letting the rear shaft and pinion slip out of the diff case. It was also chewing on the bearing parts.
