D8Te Grinding in the center diff >
Old 10-13-2011 | 09:16 AM
Unhappy D8Te Grinding in the center diff
I have a d8t that i converted to an electric with the tekno conversion kit, im running the 50/14 gearing and somewhere its got a bad grinding noise when power is applied, the grinding isnt in the motor and doesnt seem to be coming from the center diff, do i just have a bad pinion gear or is something else jacked...any help would be great!
Mcwilli13 is offline
Old 10-13-2011 | 12:23 PM
BillyCaldwell's Avatar
I would check your bearings where the pinion goes into the front and rear diff cases. I would check the rear first. I had an inner bearing go bad and it was letting the rear shaft and pinion slip out of the diff case. It was also chewing on the bearing parts.
BillyCaldwell is offline
Old 10-14-2011 | 09:18 AM
Thanks, that will be the first place i start when i get home, im wondering if i just got a bad pinion gear, the teeth dont seem to mesh exactly with the spur...
Old 10-14-2011 | 09:23 AM
What pitch pinion did you get? I am using mod 1 on d8te with a light weight steel 48 tooth spur from the hara d8 buggy.
Old 10-14-2011 | 11:37 AM
I got a mod 1 with the stock 50 tooth spur, its a turnigy pinion and a buddy of mine said those are junk, i think im just gonna swap that out and see what i get...
