MTX 5
#1156
The less changes you do to the basic setup to make the car work, the better. I agree with just droop , ride height ,and spring changes , but diff/shock oils should only be changed when all the other avenues have been exhausted ....
#1158
, and raise you a
#1159
Riketsu if you change the basic setting(complete!) and if you have to cut some radio plates,change a lot of components(options) and copy the MTX5 bumper that means that your car isn't the ULTIMATE CAR!!!
see you on next race my brother "manito"!!!
#1160
well the mugen have a lot of traction and the km has his traction too but I have to give 3.5 of toe in on the rear for plant the car on the in field, the mugen clutch is far superior for the km, the mugen clutch have moore punch and is moore agressive(something I like!) the km have tons of steering and in some way is moore responsive car, so I installed the flex system to the km to make it moore easy to drive, mugen out of the box feels the same way as the km with the flex system! I like both cars but I need to see the times for the next two local races to give an acurate opinion of both cars, but right now I feel the mugen just the way I like it!!! I use to drive mugen before km and I feel back to what I love of a car!!!
#1161
If the basic setup works, then it works. If it doesn't you have to keep at it. Saying that the closer you are to the stock setup is the faster you'll be is plain wrong. I can look at Fukuda's setup from the 4 and the 5 as well as Pietsch's setup from his cars and see many differences.
I like to test different things, if it makes my car faster, why not do it?
I didn't see you complaining when we dropped Xray diffs and Xray transmission on the MTX4.
Saying its a copy of the "MTX5" bumper is wrong. Pietsch didn't invent the Lola bumper or its cutouts.
I did back-to-back tests at the Nationals and felt it better that way.
Its nice to see you have a very good overview of the MTX5 from 3 tanks of testing at the track and a destroyed rear end...
I did back-to-back tests at the Nationals and felt it better that way. well the mugen have a lot of traction and the km has his traction too but I have to give 3.5 of toe in on the rear for plant the car on the in field, the mugen clutch is far superior for the km, the mugen clutch have moore punch and is moore agressive(something I like!) the km have tons of steering and in some way is moore responsive car, so I installed the flex system to the km to make it moore easy to drive, mugen out of the box feels the same way as the km with the flex system! I like both cars but I need to see the times for the next two local races to give an acurate opinion of both cars, but right now I feel the mugen just the way I like it!!! I use to drive mugen before km and I feel back to what I love of a car!!!
#1162
t
Bishop, you say the car handles ok and it is quick, yet you have some small problems on exit on throttle. Mate, don't go soft! a soft setup on a fast bumpy track like Brendal will just feel atrocious! go with a dark blue or higher spring setup, also like Dan said go with a narrow track width left to right. go 198 rear 195 front (or as narrow as you can front and rear).
on the S section after the front straight make sure you always stay on throttle and never back off totally otherwise witht he bumps in that section the car will spin out there. Stay on throttle and never back off totally, do this all the way until the back straight.
I dont think you really grasp just how bumpy brendale is now. Let me put it to you this way, entry to turn 1 is like a set of whoops on a BMX track!!! You have to take a very narrow line into that turn now or you WILL end up almost if not IN the grass. A stiff will simply not work. To make your car work at brendale now you have to work out how to make it accept the bumps.
#1163
:lol:
I did back-to-back tests at the Nationals and felt it better that way. Its nice to see you have a very good overview of the MTX5 from 3 tanks of testing at the track and a destroyed rear end...
:lol:Shu You know I love you bro!!!
#1164
I realy don´t understand some topics and ideas in this thread. All cars come with a basic setup, and that setup is intended for a specific track someware in the world (probably the track that R.Pietsch tested the car most). If you are going to a different track, you will need to setup the car for that layout, surface etc, etc. That´s RC basics. That´s why the car comes with multiple setup possibilities.
Then, the car was highly waited? Yes. And the first two big results are european champion with Robert and Japonese Champion with K.Fukuda.
Please tell me what car did you test for the first time in your local track, with basic setup, that was just perfect. I will buy 10 of those.
I haven´t recived my 5 here in europe yet, but when i do i shurely know that:
- basic setup is just a setup, and i´m 99% sure that it won´t fit the tracks that i run.
- roberts setup is just the setup for that specific track were he was crowned european champ. It will not be perfect for my track or my driving stile.
- I will have to develop my own setup, not doing just what the others do in their tracks. It will be my setup based on what the car tells me it needs running on that specific track.
Best regards.
Luís Cortez
Best regards.
Luís Cortez
All I will say is this, with people like your most knowledgeable self giving friendly advise is a complete waste of time.OH by the way thanks to you will probably buy something else instead.
bishop i hope you are able to improve your car setup as it sound like you are getting to the bottom of the problem.good luck and enjoy your journey
#1165
Tom,
The setup discussion on this thread is awesome, and I'm taking notes for future reference every day. The copy and paste function is working overtime on my computer. Thanks for all the contributions.
Kindest regards,
Lars.
#1166
Tom,
Brendale was a killer layout..if i remember correctly when i raced there yonks ago i thought to myself "this layout is way better than mbank!"
#1167
Kindest regards,
Lars.
#1168
Manito don't get mad jajajaja
#1169
And for those 3 tanks, the clutch was giving you a lot of trouble...
I do know how to read and write.
I may have exaggerated on the word "destroyed", but spending more than $30 on a repair for me is "destroyed".
And I am not mad... Im just
with everything you write
#1170
For those of you who are having trouble with the new clutch here is what Ive found thats works really well. I used the silver mugen clutch spring and tightened to 1.4mm. Set the end gap to .70mm. I trimmed the corners on the sling weights as to allow them to come out without rubbing each other. Try to experiment using more or less tension on the spring and .6-.7 gap on the bell. I like to take the tension on the spring to the point where the clutch slips and than I back it out a 1/4 turn. good luck
