RC10B4.1 FT/WC
Old 10-04-2011 | 02:27 PM
  #6271
bds81175's Avatar
Moderator
Originally Posted by RickSlick
Just used fishing weights with velcro to weigh down my B4.1.........just pennies each and they come in all sorts of weights.
You might want to shoegoo them in. Weights tend to fly around the inside of your car if they are just velcroed in.
bds81175 is offline
Old 10-04-2011 | 02:31 PM
  #6272
Asharus's Avatar
+1
I had one of my weights from the rear triangles shoot into the servo compartment. I thought I was glitching but it turned out to be a wedged weight in my servo compartment intermittently causing my servo to lock up.
Asharus is offline
Old 10-04-2011 | 04:50 PM
  #6273
bds81175's Avatar
Moderator
Originally Posted by Asharus
+1
Didn't you fry a servo that way too?
bds81175 is offline
Old 10-04-2011 | 05:19 PM
  #6274
Asharus's Avatar
Nope servo was fine. I believe this has happened twice now though. Those Savox servos are beasts.
Asharus is offline
Old 10-04-2011 | 06:36 PM
  #6275
YankeeFan123's Avatar
yes they are. they can handle everything you tell them to
YankeeFan123 is offline
Old 10-04-2011 | 07:04 PM
  #6276
916bdogg's Avatar
Thumbs up AE Is Killer Of All......
oh Man can't wait a true AE +8mm Chassis , I knew it !'
Attached Thumbnails RC10B4.1 FT/WC-b4longchassis-spy-shot-3-300x194.jpg
916bdogg is offline
Old 10-04-2011 | 07:12 PM
  #6277
Jmuck69's Avatar
NIce and looks like updated springs!
Jmuck69 is offline
Old 10-04-2011 | 08:19 PM
  #6278
BrentH's Avatar
Looks like it's sitting in the conference room
BrentH is offline
Old 10-04-2011 | 08:24 PM
  #6279
better drop your price to sell sell sell before they make it Ahahah
Old 10-05-2011 | 05:09 AM
  #6280
jkirkwood's Avatar
Originally Posted by Jmuck69
I would try the standard brace. Carbon parts make a difference but would be my last resort when trying to dial out grip. High traction tracks are where the carbon parts shine.
Depends on the traction your racing on , if you have med to high traction the carbon is better because your ride will be easier to drive and make fewer mistakes ..
If traction is slippery , the plastic will be easier to drive ...
With the 8m ?
Carbon arms , rear U-brace , nose plate ft arm brace will be the ticket , as the 8m has more traction than the standard chassis ....
The carbon U brace by it self is a small change compared between the plastic U , if you are having traction issues try a lower ride height , ck your slipper and tires first before switching ....
Thanks for the feedback. I'll try the stock brace next time I'm at the track but I've been running on what I could call high traction (CRCRC & RC Factory). There is just something wrong with the car, I can make big swings at the setup and it just doesn't change much. Example went from zero washers to 3 under rear link Saturday just to try to feel a major change. It's twitchy and loose; the front end will never release coming on power. I'm going through the car this week, I'm hoping I find something cracked. I read on Opple with someone having a similar symptom and people recommended gluing the servo saver. Any thoughts on this? I have been running the car with the heavy servo saver.
The bad thing is I'm 2.5 hours drive from a track. Makes it hard to find the cause of stuff like this.
jkirkwood is offline
Old 10-05-2011 | 05:13 AM
  #6281
Jmuck69's Avatar
I glue my servo saver. its good for long sweepers and getting rid of that snap back in your steering. Most modern servos are metal gear so having a servo saver is really not needed. gives you a more direct feel.
Jmuck69 is offline
Old 10-05-2011 | 05:25 AM
  #6282
F18engineguy's Avatar
Keep in mind, if you glue it you might just end up breaking the servo rack…seen it happened.
F18engineguy is offline
Old 10-05-2011 | 07:10 AM
  #6283
xtraman122's Avatar
True story, I broke two in one day... Needless to say I didn't glue the third.
xtraman122 is offline
Old 10-05-2011 | 07:11 AM
  #6284
kyle3333's Avatar
Awesome.
kyle3333 is offline
Old 10-05-2011 | 07:28 AM
  #6285
Jmuck69's Avatar
Haven't broke one yet. "knock on wood"
Jmuck69 is offline
