RC10B4.1 FT/WC
#6061
I'm going to admit I'm new to this and have learned a fair amount by reading this forum, having said that.............
What is the hoopla over the V2 shocks? How do they improve the B4.1 and what effect do they have?
Also, what would be a good spring to use with these if they really are an advantage on a clay track with 2 jumps and alot of turns that are fairly smooth?
#6062
the v2 shocks are awesome!
1. no need to change oil every raceday very little dirt gets in like the old ones
2. the o-ring housing is alot better. no more stupid plastic clip to hold them in
3. alot smoother and i find the care jumps/lands better.
for springs greens in the rear, browns up front. honestly though talk to the guys at your track see the setups they run for shock settings
#6063
so i am building my 8mm chassis or half way built. I sanded the cut and glued with super gorilla glue which is thick like a med c.a. Then i hot glued some aluminum braces in the outside and inside of the car. Tomorrow i will cut a peice of aluminum very thing high grade stuff, brace the bottem with it and glue it then cover with contact cement, Should be better than one peice i asked my dad for help this time... lol i guess that is cheating
#6064
#6067
#6068
Even if it did crack with use ?
Just a spot of glue again and your good to go ....
My 8m has been running for about 2 months now , no break or even a touch up required thus far .
#6069
Thanks for posting your method a while back on this thread!
#6071
yea i will pick it up but i use the gorilla to glue my tires it is just as good as c.a but i guess c.a is better for 9 bux a bottle. I only use hot glue for brace.
#6072
Hot Glue is not going to hold any bracing there. You really need to take the advice from the other members on this thread. They have alot more experience than you in regards to doing this.
#6074
#6075
ik ik i trust you since you sell them and make them. Epoxy is all i have right now to hold the seam together, i think its the stuff that is for plastics. would that be alright?
