B44.1 Thread
#646
Here's what you need.
http://order.aeteam.net/product_deta...?Itemcode=9785
I have the original B44 and bought this as soon as it was available.
#647
From: Conducting aggressive board meetings at my local track
#650
I built my B44.1 a few days ago and yesterday i hit the track with my new car. Everything was build likje the manual.
After 4 runs my rear gears in diff box cracked. After rebuild, I shimed it without any gaps in int. At the 8th run the same happened with the front gears.
After opening the front gear box at home, I found much play between the both gears.
Im running an LRP X12 6.5t 4dot timing in my B44.1. The slipper is build like manual.
What am i doing wrong with the gears, or are there any hints ?
#651
#653
My gear boxes are shimmed like crazy. I got the mesh as close to perfect as I could and there is zero side to side play.
#654
Shimmed correctly with the slipper not locked down this should not be a problem. The only time I had issues was on very high grip track with a tight slipper and agressive throttle finger.
I might be mistaken but I do believe the original B44 manual specified 4 shims on the short outdrive with 3 on the long. The new manual shows 4 and 2.
#655
Yes you are right Tom. 44.1 manual shows 4/2.
Tonight i'll try to shim it, like there no sideplay and no gap between the gears.
I think it is also a problem of my slipper setting. It is very hard closed. The front gears broke when I came down on Carpet and tried to push forward with agressive punsh.
#657
little off topic....
Anyone running a LRP TC Spec V2? My fan stopped working, the ESC didn't didn't overheat, but it was hot enough for the fan to engage. Does anyone know of a heavier duty fan that will work worth this ESC?
Thanks.
Thanks.
#659
As far as the shims, your goal is to have a smooth mesh with as little side to side play as possible. Mine are weird. I think my front has 7-3 and my back has 8-2. I took everything apart last night and there is zero wear on the gears after an hour total of run time.
#660
1Likes
