Engine just stopped >
Engine just stopped
Engine just stopped
Old 09-21-2011 | 12:01 PM
  #16
Will the tuned pipe from the engine fit an lrp .28 or lrp .30?
losifan94 is offline
Old 09-21-2011 | 12:24 PM
  #17
Revo-lution's Avatar
Glow plug detonation. That's why the damage is at the top of the piston wall and not the bottom where a bearing scrap would have gotten it.
Revo-lution is offline
Old 09-21-2011 | 02:59 PM
  #18
What is "glow plug detonation"?
Detonation is premature burning of fuel and air mixture. To fix that problem he could/should have changed a head shim or used a different plug (heat wise).
The damage on the top of the piston and down the sleeve is from a up stroke of the piston catching a fragmented piece of metal in a port. Seen that more then I'd like to talk about. The pitting on top of the piston could and probably is from detonation or some like to call it "pre-det".
got_nitro is offline
Old 09-21-2011 | 03:48 PM
  #19
I think it was the glow plug because I recently changed it. However I was only driving it for a few minutes before this happend. Maybe the previous run ruined it and it just needed to be used a bit longer to fall apart and break the engine.
Old 09-24-2011 | 06:16 AM
  #20
Originally Posted by losifan94
Will the tuned pipe from the mach .26 engine fit an lrp .28?
Will this work?
HTML code is On
