RC10B4.1 FT/WC
#5746
Quick question about the V2 schocks: I just received a set from a parted out kit and they guy forgot to include the spacers for between the o-rings. Are these the same thickness as the old ones? If not, how thick are they supposed to be? Thanks!!!
#5747
http://www.rctech.net/forum/electric...am-thread.html
#5749
Just use the old white plastic ones. Some people prefer those and Kyosho Grooved O rings to prevent leaking. I believe it's been said that the new black spacers are too thick and compress the o rings and cause leakage.
#5751
http://www.shortbusracers.com/2011/0...shock-leaking/
It's how I've built all of my v2 shocks and I can tell you that none of my shocks have ever leaked.
#5752
I've got the McMaster Carr x rings in my V1 shocks on my B4 and in my V2 shocks on my kids SC10 and they work like a charm. Dirt cheap too. Can't feel the stiction that some folks have talked about but maybe I just lubed up better.
#5753
I run the same rings. I noticed some stiction after lubing up throughly. I'm going to try running one X ring on the outside and one AE ring on the inside.
#5756
#5757
i think it was wild cherry who posted about using 0 degree hubs and putting no washers under the stud, thanks! It works really well and very easy to drive, i did add the plastic arm brace which idk if i gained some steering but around 180 turns my car hugged them like a magnet!!
#5759
