1/12 forum
Here are a few setups with similar tires sizes for stock and mod.
Slightly larger rear dia.
Though different compounds, at the same event.
Mod
http://www.teamcrc.com/crc/downloads...09IICsetup.pdf
Stock
Mod
Stock
Hey just quick question.
Is Tekin still the ESC for 12 scale or is there a better and/or more user friendly esc for single cell out there.
The reason for asking is I have a Teking It's in my wgt. and don't really want to do the swap thing. So looking for a new esc for the GenXL.
Thanks in advance.
Thanks in advance.
Thanks in advance.
Thanks in advance.
No heat sink or fan needed for 1 cell and integrated booster also capable of running a 2 cell
All the Features also great price and Loads of support on the forums here.
running it in my GenX 1/12th 10.5 boosted Should be fun
Thanks in advance.
Thanks in advance.
Champs BABY!!!!
Mod
Stock
Mod
Stock
can you tell me what this gives ???
Thanks Phil
SXX V2 manual says that boosted 10.5 should run about 48mm of rollout with the X12 motor, and though it doesn't say I think it would be a little more with a different motor, like 52 or 53. Just use slow-ramp boost setting 3 or 5 and it should be fine
Opinions and setup taste vary, you have to find what is comfortable for your style.
The 2mm offset is more of a "guideline"
I use tire diameter split as a tuning aid. If you need more steering, reduce the split. If you need less steering, increase the split. 2mm difference is a good starting point for 1/12th.
interesting info, so when you reduce the split is this referring to same size front to rear, and less steering front smaller and larger rear's, I've never though about using tire size as a tuning ad.
I found a CRC carpet knife that seems to be in brand new condition with a Tekin RS pro esc, Fantom ion2 motor, sr300 reciever, digital servo, and a team checkpoint 50c 5000 lipo. What is a good price for this set-up? thanks
75 chassis
125 esc
50 motor
50 receiver
50 servo
25 lipo
Here is a 12th mod setup, with the same size frt and rear tires.
This driver is fairly quick too...
Thanks for the help, its a second hand ESC so no manual.
2991Likes
