Tamiya mini cooper
Has anyone seen results from the first day of racing at the TCS finals? Really curious to see how things have been affected by the new, very strict, handout motor rules in the mini class.
FYI, for this race they've set up a handout system where you go to pre-tech, get a motor, install it right there and race. After the race the car is impounded and you uninstall the motor at post-tech. No oil, motor spray or comm drops allowed. Stock bullet connectors and wire...wow. Should make things interesting. The fast guys will still be the fast guys, but the rest of the field might tighten up.
Yeah wow that much control is CRAZY! Isn't part of the sport and fun being able to tune your car and hopefully get the edge over your buddy? Or just being bored and curious and wanting to play with your car? That's a lot of freedom being taken away.
Can anyone please help me out with this?
If I use short springs that are smaller than the stock springs, do I need to use a bunch of those clip on spacers so the shock isn't compressed at all?
I'll be using my stock Tamiya TA05 oil filled shocks.
From memory three front and two back but then you have to put the front shock back together a different way because there is so little travel left in the piston that you can no longer slide in the spring platform! Lol
), the oring somehow lost a little bit of its elasticity and stretched causing unequal shock length. Plastic spacers are the way to go
295Likes
