JConcepts Thread
#4171
re: hazard wheels sc10 4x4, so you are saying the truck is 6mm narrow not the 3mm the AE website shows?
when I run blitz wheels which have 2mm per side more width I am 1mm too wide according to the ROAR rule book.....
AE website says 293mm width
ROAR width rule 296mm max
#4174
Hi guys, looking for some advice. I race on an outdoor track that is run wet during club races, double dees are great when it is wet. During practice early in the day or if I go out on a practice day its impossible to keep the track wet until the sun goes down, so here is my question, Which compound should I use if I wanna run out there during the day? The track would be dry, dusty and extremely abrasive. I want to run a tire that will not wear, not to concerned with grip just something that will last more than a few practice days instead of a few batteries. I guess Im looking for the hardest compound barcode that they make.
Thanks!
Thanks!
#4176
I haven't actually measured mine. But I do know, at the Nationals last week. The handful of guys running Hazzard Wheels on the SC10 4x4, passed thru tech every single time. Tech was a basically a large carbon fiber horseshoe type thing that checked width. No way to cheat that.
#4178
Awesome, now get them out so I can buy them
#4180
What is this? Are you coming out with spur gears? This is from your page on the Nationals.
· Hi-Flow body
· Ford Raptor body
· Manta V2 body
· Bar Codes tires
· Profiled closed cell inserts
· Hazard wheels
· Rulux wheels
· Advanced Formulated Tire Glue
· 8/32” serrated wheel nuts
· 4mm serrated wheel nuts
· S.S. 84T Spur gear
· Hi-Flow body
· Ford Raptor body
· Manta V2 body
· Bar Codes tires
· Hazard wheels
· Rulux wheels
495Likes
