RC10B4.1 FT/WC
Old 08-20-2011 | 08:25 AM
  #5281
racer1812's Avatar
Super Moderator
Originally Posted by SC-Racer
Need some expert advice on my B4.1 buggy. I finally got it set with great initial steering. The problem is that it washes out extremely quickly. I don't want to loose the initial steering that I have but I want to keep my steering more consistent through the turn without washing out. What should I look at to adjust? I notice this most with off power steering. Thanks for any help you can give me.
Are you still on the brakes when it starts to push? The 4.1 honestly turns REALLY well off power/under braking. If you're releasing the brakes and letting the car roll through the rest of the turn that could be your issue. Your one of the very few people I've heard say they have an off power steering issue.
Honestly the easiest way to know if it's you or the car is to have one or more local fast guys drive your car and see what they say. I've been racing forever but when I first started 2wd buggy I just couldn't get it to work. I had to suck it up and ask the guys faster than me to drive my car. While it was nice to hear that my set-up was really good it meant I had to change my driving style, not the car. After doing so and driving a few different cars only now can I say that the 4.1 turns better than most on the market, which is what many people think.
racer1812 is offline
Old 08-20-2011 | 02:45 PM
  #5282
Does anyone know if big bores will fit on a t4.1, I just dont know if they will clear the turnbuckles during steering. Thanks.
Poptartninja is offline
Old 08-20-2011 | 03:03 PM
  #5283
Registered User
Originally Posted by racer1812
2.95" or 75mm roughly, center to center on the inner hole.
75mm is the distance between the holes on the new towers or the old tower?
Ryno B4.1 is offline
Old 08-20-2011 | 03:22 PM
  #5284
racer1812's Avatar
Super Moderator
new tower
Old 08-20-2011 | 04:25 PM
  #5285
No, I usually am not on the brakes. Some of the corners at my track are too slow for you to take the entire corner with brakes. I would just come to a stop.
I am assuming I should be looking at my front camber links. Is that correct? If so what adjustments should I try?
SC-Racer is offline
Old 08-20-2011 | 05:43 PM
  #5286
D-Rek07's Avatar
What gauge wire do you guys use to connect from your esc's to your motors?
D-Rek07 is offline
Old 08-20-2011 | 06:13 PM
  #5287
Buckaroo's Avatar
TQ Racing 13 gauge.
Anything RC product that's 12gauge should be more than enough. Pick your brand, darn near everyone has something.
Buckaroo is offline
Old 08-20-2011 | 06:24 PM
  #5288
D-Rek07's Avatar
Originally Posted by Buckaroo
TQ Racing 13 gauge.
Do you know anyone that uses 14 gauge?
D-Rek07 is offline
Old 08-20-2011 | 08:55 PM
  #5289
Finally had a nice solid run with the B4.1 extended chassis, I really struggled with it the first time out, so bad I was close to throwing the towel in. Anyways I was using cavs worlds set but I had installed Kyosho big bores with yellow springs in the rear and pink in front. Starting the day out the car was not bad but I decided to throw the v2s (std cav setup)green rear/brown front back on to see how it felt and it was much much better! I really think its a matter of finding out the right springs for the big bores and they should be good as well. Ended up taking TQ, led some of the main, came home second, car was real nice and stable.
Brian Alderman is offline
Old 08-20-2011 | 09:13 PM
  #5290
mjk1210's Avatar
I've got 14g from esc to motor right now. Had 12 but needed to re-wire and had 14 so I used it. Haven't noticed any negative results from it.
mjk1210 is offline
Old 08-20-2011 | 09:23 PM
  #5291
mjk1210's Avatar
try shortening the front camber links. Really need more details about your setup though.
mjk1210 is offline
Old 08-20-2011 | 09:41 PM
  #5292
Teambcw's Avatar
I was wondering if some of you guys could tell me how much more maintenance there is from 13.5 to 8.5. I don't have much wear and tear do to lots of power just running 13.5 w/ no timing. So anyone who has made the switch please help me decide if it is worth it, i practice a good amount and don't want to have to wrench more then I drive. Thanks!
Teambcw is offline
Old 08-20-2011 | 10:21 PM
  #5293
Wild Cherry's Avatar
Practicing a whole lot, week after week wears the car , not the motor as both are very close when considering wear & tear.....
Wild Cherry is offline
Old 08-20-2011 | 10:25 PM
  #5294
Teambcw's Avatar
Thanks for the info cherry, I was told by two different people two complete different things. One said stock wore out faster, don't know how, and one said the power of his 8.5 wore things a ton faster.... so i just don't know what to think...
Teambcw is offline
Old 08-20-2011 | 10:31 PM
  #5295
We can debate for pages how much more or less the motors affect the wear & tear ...
Rather not .....
Important to just say wear is not so much more with the mod . Rather its the miles how many packs you burn a week ...
