Tekno Conversions Thread
#7428
anyone else have problems with the long shank pinions snapping off teeth? on my second run with my MBX5T tekno v3 conversion, a tooth completely snapped off. the pinion literally only had about 10 minutes of run time at the most. kinda bummed that i spent $7 more for it when i discovered i can run a regular mod 1 pinion.
#7429
#7430
#7432
i have mine set so it moves the motor mount forward. i just bought the long pinion because everywhere i read said you had to use them. oh well, now i know i don't need to.
#7433
help with d8 conversion please
Wow! long thread, getting a D8 and a Tekno v4 converson kit, still up in the air on direct drive vs clutch bell set-up, mostly bash but rarely race,lots of street beatings. I have a Castle 2650 to go into it, seems a bit large compared to most people liking the lower kv motors and more battery. If I stick with the 2650 what count lipo would be recommended for the driving that I do, using a MMM. Also if I decide to get the clutch bell set-up, would like gearing suggestions THANKS !!
oh yeah, mech brakes ?!?
#7434
So I had my first race with the Mugen Tekno V4 and the car was on rails. Felt like a slot car. Very stable. I qualified 4th at RCX Chicago in Pro Buggy. I have never run that fast and consistent... EVER.
Unfortunately, I was the only electric in the A Main and they ran a 25 minute main (after saying it was 20 minutes initially). I had to put a 6s 4000 pack in the car when I normally run a 6s 2650 and it made my set up drive like a drunk donkey with roller skates on in the main. My two year old Hobby City 6s 4000 pack with a weak cell dumped at the 23 minute mark too. Owell...
Loving the car though. I am a believer.
#7435
Alright this question is on the 8ight 2.0 V4. Directions say to use the rear motor mount slots for standard pinion/motor brake setups. Any other combination will use the front slots. Are the directions wrong? I'm using mechanical brakes and was hoping to use standard pinions since I own a bunch of those already. But I can't mount the motor in the forward position because it hits the brakes. Check it out...
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
#7437
I'd go with a 15 or 16.
#7438
Whether to run clutch or DD is personal preference. Traktion Drive is great for racing but the only benefit when bashing will be driveline protection as you wont benefit a great deal from the improved traction. I would probably keep it simple and stick with DD.
Cant help with gearing as i'm not familiar with D8's.
Shame about the long final. For a 25 minute main i would stick with a set up that runs between 10 - 15 mins and factor in a pack change.
We have about 15 e buggies and only run 10 min quals / finals but in E truggy we run with the nitros so have 20 - 30 min finals. We do a pack change at 10 minutes and i came 3rd in the A main last week (1st out of 3 in e truggy), so even with a long pit stop it is still possible to place well. I guess it does depend on how tight the field is but i always count on the fact that nitros flame and it usually pays off.
#7439
I can run against nitros for 25 minutes on 2s 8000mah x2 for 4s saddle pack easy with no batt change and love hearing the nitro guys cry while I take 1st and only come off the track @ 3.7v per cell (TP 35c 8000mah 2s)
I do gear low when forced to run with the nitros, I go down to 46/15 from 44/17
My car only weighs 7lbs. 12oz. in that setup and is very balanced left to right with a 51% front weight bias.
I use either an RX8/1900 or an MMP/1800 with TraktionDrive
I run a 8 2.0B with a very custom chassis that offers a custom layout and wheelbase that no one has out of carbon fiber
#7440
I am running pretty much the stock setup. I changed the diff oils to 10 7 3 I believe. Only other change was dropping anti-squat to one down on the rear suspension arm carrier (the front one in the rear). Shock oils 35 front 30 rear. Stock springs and pistons. Normally run a 6s 2650 pack.
The track was pretty small, so I ran a 5s 2650 for the qualifiers geared 14/44 with a 1400kv motor. I didn't have a 5s pack big enough for the main, so I opted for a 6s 4000 pack. I knew it would make 20 minutes easily, but when I got up on the stand they were like the main is going to be 25 minutes! WTF? I probably could have made it if the pack was newer, but it has a weak cell and hardly ever run it longer than 15 minutes. More of a practice truggy pack.
Crazy thing was my buddy offered me his 6s 4500 nanotech with one run on it. Would have easily made it. It was smaller/lighter too than my 6s 4000. I just didn't feel like soldering. Also, my rx8 died when I went out to practice before the mains so I wound up spending the 1.5 hour break swapping ESCs out and didn't have time to fix the setup. A battery swap wouldn't have worked at that race with the level of Pro's running. Adam Drake won. I was just stoked on the qualifying position even though I got stomped on in the main.
The 2650kv will be fine with 4S, bit of a handful for racing on tight tracks but large tracks or bashing it will be good.
Nice work, What set up are you running?
