Tekno Conversions Thread
#7396
I hope you guys don't mind me jumping in but I have a question just about the mounts and not a total conversion. I am converting a mini MGT to brushless and think I am going to try this Hobby Wing ESC/Motor combo : http://www.hobbypartz.com/07e-c-sl-4...v-blue-v1.html Will one of the Tekno mounts fit that motor? If so which one do I want?
Thanks,
-Joe
Thanks,
-Joe
#7397
might also need a metal gear spur which leads me to my next question..
i converted my 8 2.0 to electric with the V4 and i'm using mech brakes and the nitro diff mount. I wanted to use a plastic spur to make it a lil quieter but it hits the metal washer of the vertical brake shaft on the the top of the nitro diff housing. Is there something I can do or use so I can mount a plastic spur and at the same time use mech brakes?
#7399
Tekno V3 -vs- Tekno V4
Whats the difference? it will be for a Hot Bodies Ve8.
Have a chance to pick up a V3 and want to know the major differences are.
#7401
Can anyone post a pic of a Hot Bodies Ve8 - V3 so I can see the difference in the layout?
#7402
Thanks I just have an op. to pick up a V3 for a great price, my main concern with the stock Ve8 chassis is the pinion. I ground the shaft on the motor but it is still only 2-3mm from the battery. I actually rubbed before I ground it.
#7404
I drove a V3 and V4 on my mbx6 and the only thing I can say is that the V4 is dialed.
#7405
I ran my V4 mbx6 for the first time on sunday and i was surprised to find i was quicker with my old V3
I had changed a few settings during the build (i know i should have left it alone) and i'm now running the new silver springs which apparently get better after a few meets, so i'm going to go back to my old set up and let the new springs break in and go from there.
On the other hand my V4 6T is on fire. I was stoked to get 3rd fastest lap of the day and i am loving the handling of this thing even more every time i drive it.
MBX6T / HW 2000 / 150A xerun sensored
MBX6 / Tekin 1900 / MMM
#7406
Summer Sale
We are having a little summer sale!! The following Tekno part/kits are on sale for a limited time. A Main already has the parts on special. They will be available directly on our site at the end of the week at sale prices:
TKR4501 V4 Conversion AE RC8B
TKR4504 V4 Conversion Mugen MBX6
TKR4505 V4 Conversion Kyosho MP9
TKRH67819 Lightened LCG Chassis for HB D8T
TKR401442 V3 Conversion Jammin' X2-CRT
TKR400742 V3 Conversion Mugen MBX5T
TKRL1712 Shock Tower (8T 1.0/2.0, front)
TKRL1714 Shock Tower (8B 1.0/2.0, front)
TKRL1735 Shock Tower (8B 1.0/2.0, rear)
TKRL1741 Shock Tower (8T 1.0/2.0, rear)
#7407
#7410
Question on mechanical brakes for the 8ight. I bought a full set off Ebay. Included the center diff, links, brakes, everything. However, it seems the nitro setup would have the servo on the opposite side as the Tekno kit does. If I turn the linkages around though it would need to push to actuate the brakes. Do I need to turn the cams around so it's a pull action?
