The Speed Passion Thread >
Like Tree57Likes
Old 07-13-2011 | 03:20 PM
  #7471
How do ya get the 508 software, I only saw the 323 software on the speedpassion site?
Reck83 is offline
Old 07-13-2011 | 09:05 PM
  #7472
OVA's Avatar
OVA
Originally Posted by Solara
OK...your ESC is probably 2+ years old. Contact Speed Passion USA and let him know you have the old lower case, we have the smoke clear version of the GT2 Pro bottom case for you with the ESC decal....just pay shipping and he will take care of that for you. With that bottom case, you will see the red LED blinking light from the bottom/side.
Got it ..Thanks
question what program software do I need to upload for blinky ?..right I have the 528
OVA is offline
Old 07-13-2011 | 09:09 PM
  #7473
Korey Harbke's Avatar
Franko,
Use 508. It should be in any of the latest software packages for the handheld USB programmer.
-Korey
Korey Harbke is offline
Old 07-13-2011 | 09:11 PM
  #7474
OVA's Avatar
OVA
Originally Posted by Korey Harbke
Franko,
-Korey
Thanks korey..I just found the answer a few pages back...Thanks again
OVA is offline
Old 07-13-2011 | 09:21 PM
  #7475
OVA's Avatar
OVA
where can I get the 508 software?
OVA is offline
Old 07-14-2011 | 05:28 AM
  #7476
Pattojnr's Avatar
http://www.speedpassion.net/uploadfi...30GT110323.zip
Pattojnr is offline
Old 07-14-2011 | 05:34 AM
  #7477
Pattojnr's Avatar
ok i have a question. i want to put 2 fans on a Speedpassion heatsink, and i would like to know the best way to wire them up.
1, wire up the 2 fans in parallel , plug it into the reciever.... or
2, wire up the 2 fans in series, and run direct from the battery.
i am asking this due to using a 3 racing twin fan setup. i had a funny thing happen to a speedy, GT Pro 2. it just stopped. i lost power output to the reciever, yet fan works on Speedy. did i overload the capabilities of the power supply to the Reciever ? or i had other issues ? i dont want to fry another one, so i was thinking about wiring up the 2 fans in series direct to battery power.
any help would be great, thanks.
Pattojnr is offline
Old 07-14-2011 | 09:17 AM
  #7478
OVA's Avatar
OVA
Thanks dude
OVA is offline
Old 07-14-2011 | 09:45 AM
  #7479
508_no_timing is within the zip file that is under the 323 software...all of our software contain all the software that you will need, you just need to pick the right one for you...like 205G, 528stock 528mod, 323stock 119mod....all within the same program.
Solara is offline
Old 07-14-2011 | 09:52 AM
  #7480
I use your option #1 and #2 mixed......I mounted (2) GT2.1 ProStock fans, directly from the ESC batteries male bullets plug, in PARALLEL. That works out very good on no timing racing...and semi ok for boost 17.5 13.5 as it draw alot of power to the motor and made the fan slowed down by alot.
The fan can take 8.4V no problem...but don't expect that to last forever. I replaced it twice within this year...
Of course, powering from the receiver is OK too...but again, if possible, use parrallel, in series, just too slow for a 5V fan....
And your last option also work too...just not too fast of a fan if mount 2 in series....
If you don't want to replace fans...your best option is use the GT2 Pro 25mm fan and use (2) receiver ports to power 2 fans...my receiver are 5 channels so I can use all all the port to power my USGT car...1 steering, 1 esc, 2 fans and 1 AMB.
But make sure this is not a ROAR (or related) event or check your country's rule book....motor can only use 1 fan no bigger then 30mm or no more then 2 fans for the entire car. (I think that is the rule)
Solara is offline
Old 07-14-2011 | 10:07 AM
  #7481
thanks
Reck83 is offline
Old 07-15-2011 | 04:39 AM
  #7482
Pattojnr's Avatar
Thanks Solara.......
Pattojnr is offline
Old 07-16-2011 | 04:09 PM
  #7483
ETA on the MMM motors anyone?
inpuressa is offline
Old 07-16-2011 | 04:59 PM
  #7484
LonnyJ1950's Avatar
Originally Posted by LonnyJ1950
Running 13.5 boosted 1/12TH scale with EX 2.1, 323 software, Trinity Nemesis, medium size mildly technical track 100' straight. Set up suggestions?
Come on someone must run 1/12th for Speed Passion.
LonnyJ1950 is offline
Old 07-17-2011 | 02:34 AM
  #7485
I will be running them later in the the year but now it is our outdoor season
sidecarphil1 is offline
