RC10B4.1 FT/WC
Old 07-10-2011 | 09:18 PM
  #3901
idrummerboy13's Avatar
Originally Posted by D-Rek07
Any suggestions?
anything agressive works calibers or holeshots
idrummerboy13 is offline
Old 07-10-2011 | 09:40 PM
  #3902
Any suggestions?
Sorry D-Rek, I was waiting for some of the U.K. drivers to chime in..I would run Holeshots or DD's, maybe even an older set, as you you should get plenty of traction..
flame56mx is offline
Old 07-10-2011 | 09:48 PM
  #3903
mellow's Avatar
Originally Posted by Matt Trimmings
It sounds like you are doing something wrong if you are rebuilding a ball diff every weekend. Mine would last a few months before a rebuild.
Definitely doing something wrong..Should last WELL over a month on a proper built diff.
mellow is offline
Old 07-10-2011 | 10:04 PM
  #3904
Teufel Racing's Avatar
+1 on the something being wrong on the diff,
AE diffs are about the easiest to get built right and usually last a long time with proper maint.
Teufel Racing is offline
Old 07-10-2011 | 10:08 PM
  #3905
D-Rek07's Avatar
I should have been more precise. I would like something that works good on all surfaces (Grass, street, dirt, etc.), you know, something that will work for messing around in the front yard and going in the street. I would think that holeshots would wear down really fast on concrete.
D-Rek07 is offline
  #3906
mellow's Avatar
I think a lot of people don't go through the trouble of breaking them in, so they're pretty much toast after the first couple of runs. A proper built and broken in diff should last awhile.
mellow is offline
Old 07-10-2011 | 10:12 PM
  #3907
Yeah, they will be really nice slicks in no time. Maybe something like these?
http://www.amainhobbies.com/product_...-Buggy-Tires-2
Old 07-10-2011 | 10:15 PM
  #3908
mellow's Avatar
Haha, I was just about to post up the same tires. Perfect for some bashing.
mellow is offline
Old 07-10-2011 | 10:20 PM
  #3909
D-Rek07's Avatar
Ok thanks, I have been looking at those, but just wanted to make sure there was nothing better.
D-Rek07 is offline
Old 07-10-2011 | 10:22 PM
  #3910
JFuel11's Avatar
Default Agree...
I spend as much time breaking in my diff as I do rebuilding it. Done correclty and the diff should last a long time. I am just getting ready to rebuild mine after 3 to 4 months of racing. It is well due but still smooth enough to win races with.
JFuel11 is offline
Old 07-11-2011 | 04:57 AM
  #3911
bds81175's Avatar
Moderator
Any suggestions?
Sounds like you got suggestions for bashers from others. If you are looking at running specifically on grass Schumacher makes the best tires. I've got mini spikes on the front and back of my B4 for running on my grass track in the back yard. Medium compound with medium inserts. Car is just about perfect (except for the driver).
bds81175 is offline
Old 07-11-2011 | 07:55 AM
  #3912
What kind of tires are good for grass with the b4.1?
Slicks with nails punched through them
jpcopeland1 is offline
Old 07-11-2011 | 08:56 AM
  #3913
Speaking of customer service. So I called AE, talked to Chris about my servo he said fax them the receipt and write bad servo on it. Did that last Wed. thought maybe I'll get the new servo a few weeks later. Wrong! got it 2 days later (With a return envelop for the bad servo). WOW!
GuiltyByAssoc is offline
Old 07-11-2011 | 09:44 AM
  #3914
I'm sick of getting hit from the SCTs at the track! Over the w/e at one time there were 15+ SCTs on the track and 1 buggy, guess who was driving the buggy... The carbon fiber rear arm cracked from few viscious direct hits, I've decided to get the SCT and start dishing out the pain myself.
I know Losi TEN is a great truck, but decided to stay in the AE family and get a sc10 4x4. Question- what esc/motor combo do you guys recommend (I know this is prob. the wrong forum). Budget for the combo is around $300.
1. Tekin RS PRO 6.5T- This is a more of a buggie combo will it have enough torque for a 4x4? or should I get the ESC seperately and get the SC4x 550 5.0T instead?
2. LRP-
3. Castle-
Old 07-11-2011 | 10:05 AM
  #3915
jrusso3's Avatar
2. LRP-
3. Castle-
Yep, wrong forum.. check out this thread for building and setup tips..
http://www.rctech.net/forum/electric...x4-thread.html
Personally, I suggest the Tekin RX8 (no heat issues - even without the fan!!) I choose the LRP 5.5 550 motor, but there are a ton of options.. again, check out the thread above for tons of info...
jrusso3 is offline
