RC10B4.1 FT/WC
Old 07-07-2011 | 01:11 PM
  #3811
Cpt.America's Avatar
Originally Posted by idrummerboy13
are you asking how to add steering? what servo you have.
No, hes saying he didn't think the 22 steered very well. The shame is, box stock setup is designed to make the car push... lots of people dumping the car because they don't know how to set one up. The 22 steers like a champ if you know how to set it up.
Cpt.America is offline
Old 07-07-2011 | 01:31 PM
  #3812
JFuel11's Avatar
Default It does not really matter...
I have a friend that just made the jump to the 22. It has been tough at first because it is a new platform and it takes some time to get it dialed in. I can my my B4.1 push like a barge or spin out every corner... it is all in th setup. I will stick with my B4.1 for now. Drives great and I don't feel I get beat because of a different chassis ever.
JFuel11 is offline
Old 07-07-2011 | 01:50 PM
  #3813
idrummerboy13's Avatar
the team kit setup on the b4.1 ft works so perfect on the 2 tracks i raced on which are both totally different.obviously tire change and maybe lighter shock oil for the smaller outdoor track but no major changes.. And thats actually smart to make a stock car push, i feel its easier to drive for somebody new to the hobby or car.
idrummerboy13 is offline
Old 07-07-2011 | 01:56 PM
  #3814
Asharus's Avatar
Where's the other track you race at while LIR is closed? I race at Gallimods in Baldwin Place (just north of the Bronx) and Critters every other Saturday in Jersey.
I use Vin Nocella's setup and just change the tires.
http://www.petitrc.com/setup/associa...dRC10B4.1.html
Asharus is offline
Old 07-07-2011 | 02:35 PM
  #3815
my neighbor has a sweet backyard well groomed track and timing system.
http://www.youtube.com/watch?v=2qhZg8MQlHw
Old 07-07-2011 | 03:37 PM
  #3816
B.A. Racer's Avatar
i wish i had that in my backyard!
B.A. Racer is offline
Old 07-07-2011 | 03:44 PM
  #3817
Asharus's Avatar
Yeah I've seen that vid before. I didn't know you guys had a timing system!
Asharus is offline
Old 07-07-2011 | 04:09 PM
  #3818
That was when it was new and surface was loose now it's hard packed and always damp
Old 07-07-2011 | 05:05 PM
  #3819
B.A. Racer's Avatar
so im going to be buying a savox 1258....i heard it caused cogging issues but only from one guy....anything i need to know before i spend money on one?
Old 07-07-2011 | 05:21 PM
  #3820
ilanstylz's Avatar
buy a capacitor like the spektrum cap or novak glitchbuster and your good to go..........
ilanstylz is offline
Old 07-07-2011 | 05:26 PM
  #3821
bds81175's Avatar
Moderator
I've got a Savox 4096 which I believe is nearly identical to the 1258 and I don't have cogging issues. I've got an MMP with a 5700kV motor. Bought a Novak glitchbuster but haven't needed it yet. Check out the MMP thread. They've talked about cogging with higher current draw servos quite a bit.
bds81175 is offline
Old 07-07-2011 | 05:32 PM
  #3822
They are strong and fast servos, for an amazing price.... so, if you are very budget minded (or budget limited), they are a no-brainer. If you have a little more depth to your pocketbook, I would look elsewhere as they really tax the power system. Some people have no issues, but some people do. Me? can't get me away from futaba BLS servos. They are more expensive (almost double), but they are lower power consumption, stronger, better built, and look better to boot
Do it comes down to budget.
Old 07-08-2011 | 04:11 AM
  #3823
retsoorkcuf's Avatar
Default changing ball to gear diff
What gear diff fits the t4 tranny
retsoorkcuf is offline
Old 07-08-2011 | 05:51 AM
  #3824
Asharus's Avatar
They work fine as long as you're using a legit receiver/ESC. If not, get a glitchbuster capacitor.
Asharus is offline
Old 07-08-2011 | 08:33 AM
  #3825
I need a little setup help. I have been struggling with clearing a jump section at our track and I am not sure what to do... I need more distance by a foot or two... This is just our club track so not a ton of people to reference at the track and the ones that are clearing it are using a 22.
This is 17.5 with open speedo so I cannot just throw a bigger motor at it
front
1-O
1-A with 2 washers
0 toe
-1 camber
axle middle
30 degree caster
2 bump steer
Rear
1-I
1-B with 1 washer using C hubs and ground down ubrace
-1 camber
medium wheel base
3.5 degree toe
2 anti squat
I have 25mm ride height all around and a 6" wing with 5mm lip
brown springs front #1 piston 30 weight oil with 3 limiters
Kyosho dark yellow rear #2 piston 27.5 weight with 2 limiters
gguertin145 is offline
