Like Tree5Likes
SC10 4x4 Thread
Old 07-05-2011 | 05:15 PM
  #4156
ilanstylz's Avatar
Originally Posted by jason55
Hey guys I love this forum it's helped me so much in my sc10 4wd kit build can't thank all the people that post enough for their help. So my questions are I'm getting into racing where should the slipper clutch screw be How tight for a very loose slippery track ... 2nd as far as the shocks that come with the kit what weight oil should use rite now I have 30wt rear and 35 wt in front ,as far as upgrading the bearings in the truck do you think this is worth it or are the bearings that come with the kit good enough. Thanks for all your Guys help. Any help with this would be appreciated thanks jay
I have mine pretty tight but I run on a hard packed clay track, so not sure about how you should run yours since I've never ran on that type of track........ For the shock oil I would stay with what you have in the front and drop the rear to 25w...... I've had no issues with the bearings but if there are better ones out there I don't see how it could hurt anything, but not sure if it'll improve anything.......... I'll leave that answer up to the experts ;-)
ilanstylz is offline
Old 07-05-2011 | 05:23 PM
  #4157
Default Setup sc104x4
Hey thanks for the input so I will try 25 wt in rear and keep the 35 wt in front. Thanks jay
jason55 is offline
Old 07-05-2011 | 05:29 PM
  #4158
Farmer_John's Avatar
If you run an esc that has current limiting, you can increase your traction and drivability that way. Some Expo will help. A lighter touch on the trigger will help. Proper tires for the track will help. Working on your set up will help.
Lots of laps of test and tune will help the most. It'll tell which of the things above in combination will give you your best results. IT's a steep,but fun learning curve.
I wouldn't, however, try loosening the slipper. At the stock setting (3.5mm of thread showing), you'll glaze your pads in a raceday.
Farmer_John is offline
Old 07-05-2011 | 05:53 PM
  #4159
JFuel11's Avatar
Default Double Slipper Kit is the Bomb!!!
So there is a guy on this forum selling a kit that allows you to run a double slipper pad setup for the rear wheel drive of this truck and all I will say is the kit is the bomb! My slipper temps went way down and the forward bit of the truck was plan crazy! I didn't have to pull slipper apart and sand the pads even once all weekend! I run a lot of motor in my truck and was getting concerned of the slipper holding up. Now it is perfect! I highly reccommend this kit as it has made a great truck even that much better!
JFuel11 is offline
Old 07-05-2011 | 06:19 PM
  #4160
Cackswayn's Avatar
Everyoone is fighting in the losi thread can I come hang out in here??? LoL... that clutch baske thing is a really good idea.
Cackswayn is offline
Old 07-05-2011 | 06:34 PM
  #4161
The dual slipper pad clutch basket works great. Other guys running the stock slipper with the 'high torque' pad are replacing them every run and struggle to clear big jumps late in the race, cuz they glaze so bad. I never touch it and can pull wheelies on the grippy parts of the track. I bet AE is working on a FT optional dual slipper pad/new gear cover setup as we speak.
Stealth_RT is offline
Old 07-05-2011 | 06:49 PM
  #4162
Robotech's Avatar
Did I miss this part somewhere? Don't remember seeing the dual disk option...link please?
Robotech is offline
Old 07-05-2011 | 07:03 PM
  #4163
CraigMBA's Avatar
Oh yeah? Who?
CraigMBA is offline
Old 07-05-2011 | 07:10 PM
  #4164
rednck21's Avatar
gave my truck a rewire/makeover this past week moved the esc all the way back and put it on some scales. the left front was about 20 grams lighter than the right front. looks much cleaner now IMO...
rednck21 is offline
  #4165
Originally Posted by CraigMBA
Oh yeah? Who?
http://gearrings.weebly.com/rc-racing-stuff.html
Old 07-05-2011 | 07:15 PM
  #4166
JEFFs SC10's Avatar
nice wiring job, i definitely need help in that dept.
JEFFs SC10 is offline
Old 07-05-2011 | 07:20 PM
  #4167
JFuel11's Avatar
Default Same Setup!
Originally Posted by Farmer_John
This is the same setup I ordered as well and very pleased with it.
JFuel11 is offline
Old 07-05-2011 | 07:38 PM
  #4168
Mac The Knife's Avatar
Oh yeah? Who?
Ummmm, Me.
Mac The Knife is offline
Old 07-05-2011 | 07:39 PM
  #4169
rednck21's Avatar
thanks!
put yours in the mail...ill clean it up for you
rednck21 is offline
Old 07-05-2011 | 07:44 PM
  #4170
I'm glad to hear that, as I tried just the HD pad and prefer the feel of the regular old AE slipper pads. There was absolutely no difference at all at the speed to which the HD pad glazed and even when new, it just didn't "feel" right to me.
