The New Werks B5 .21 Racing Engine
#7291
Here is some footage from todays racing of my WERKS B5 PRO that has been modified by clockwork racing engines....
http://youtu.be/H7MQ4guTvZA
#7293
The heat shield around the neck of the carb is just made of a different material that is slightly more expensive and does a slightly better job, that's all. It's not worth replacing the carb just for the shield as you will not notice a difference in how the carb functions. Regarding the new heads those should probably start showing up mid July as we are finally starting to catch up on demand.
#7294
REALLY wish that LRP had named their new plugs something else......either way, there is no replacement for WERKS................
http://www.liverc.com/news/new_produ...am_glow_plugs/
#7295
There is no new carb on the Pro models
#7302
Does it matter which nitro fuel is used. For example I could order some werks or byrons 30% online but if I run out then I have to order more and pay a hazmat fee. My local hobby shop carries 30% sidewinder. Would it make any difference on which I use.
Terry
Terry
#7303
Different fuels have different pro's and con's. I would say that most fuels will work just fine but I have found sidewinder the be somewhat hard on bearings etc. Given the three options of Sidewinder, ours or Byrons if it was me using the stuff I would of course recommend ours followed by Byrons and Sidewinder last.
63Likes
