SC10 4x4 Thread
#3571
After 3 different times at the track trying different things I'm still getting hot temps with my motor over 180* ..pinions used 13 and 14 ..going to buy more this week but has any body had to lower then 12/62 ? I'm running small indoor track lots of stop and go. I added washer to slipper plate so can clamp it down good but I notice that if I compress spring completely it Bends the spur shaft and when I turn tires be hand I can see it
then I saw that the belt actually goes up and down just a hair but. This might be where heat is coming from maybe spur had run runout causing a bind with pinion ? Just thinking out load any help or advice thanks..
setup, 1ea 2mm washer on slipper sping, full tight backed of 1/4 turn.
Steve
#3572
I use that stuff everyday at work since telecom infrastructure is my career. I would still rather use velcro, but that's just me.
#3573
I did that because I thought all the slipping was causing heat I looked at pads and they were shiny but not galazed I don't think maybe I'm wrong.. I just could tell when I hit the gas it had lag ,like. There's no way I could do a wheeliy
#3574
Thank u ,ill buy high and low but I'm glad to see im not the only one going low
#3577
Well it pains me to say this but hopefully by doing so I will save someone some of the same frustration I have had and hopefully will get some response from AE. First let me say I have bought almost ever type of kit from them from onroad, oval, truck, 18T, buggy 4wd buggy, sc, sc4wd and up to this point have loved every minute.
I built the kit and although had to make several adjustments with the drimel wasn't upset bc all my parts were there and I would have rebuilt the diffs and shocks anyway bc thats just how I am...I enjoy building the kit and knowing what I have.
Well the 1st weekend after buying the truck 2 days after its initial release I broke a rear shock tower coming off a jump...was it my fault...sure it was...was it a shotty custruction or kit, no...well I say no I only have 2 minutes of run time, but the kit seems solid.
So where is my problem, well I cant get a shocktower...heck I can't even get a call back from AE...I just have to keep calling till someone answers. Everyone is backorderd becasue they haven't released parts...I understand that they wanted to get the kit out, I really do but this is really poor planning and customer support and should have been rethought.
So why after weeks of waiting...calling and sitting waiting while others race am I posting? Because upon calling today after leaving to 2 messages regarding future parts availability, I finially get to talk to someone who says parts will be in next week...which is great...but wait...AE is closed next week due to inventory...they will be accepting the delivery and not sending out to distributors or selling for another week. This did it I am done with it...all I want is a part...I have spent $1000s on AE kits, electonics, batteries, and parts, been a loyal customer and this is what I get. My $1000s may be nothing compared to what some spend but for me it has been what I could spend and I chose them. Well no more...make it right or loose me forever I am done...I don't want anything for free just to be able to buy a part for the kit I bought from you so I can enjoy it maybe some follow up. If you have parts coming in you should make an exception and get them out. Your customers are what makes you. You are wrong.
Dominic
Dominic
#3578
#3583
Ft shocks ( no bladder)
40W 1.3 piston
7000w in ft diff & 5000w rear
Rear shock( no bladder)
32.5W 1.3 piston
battery forward
lock up clicker
under-drive pulley up ft
Lrp 4.5 550
11T pinion
40W 1.3 piston
32.5W 1.3 piston
battery forward
lock up clicker
Lrp 4.5 550
11T pinion
#3584
20 Smoke, I'm more of a black car guy than a white car guy but it would be easy enough to do...the "CAT" logos are all painted on so you'd just reverse the black and white.
#3585
5Likes
