Like Tree5Likes
SC10 4x4 Thread
Old 06-22-2011 | 08:09 AM
  #3571
Originally Posted by bronc4now
After 3 different times at the track trying different things I'm still getting hot temps with my motor over 180* ..pinions used 13 and 14 ..going to buy more this week but has any body had to lower then 12/62 ? I'm running small indoor track lots of stop and go. I added washer to slipper plate so can clamp it down good but I notice that if I compress spring completely it Bends the spur shaft and when I turn tires be hand I can see it
then I saw that the belt actually goes up and down just a hair but. This might be where heat is coming from maybe spur had run runout causing a bind with pinion ? Just thinking out load any help or advice thanks..
I'm geared 11 / 62 on small clay track, running Team Epic 550 / 4.5, more than enought power, 140 after 12 min, esc 98/100, very happy with this
setup, 1ea 2mm washer on slipper sping, full tight backed of 1/4 turn.
Steve
sbales is offline
Old 06-22-2011 | 08:11 AM
  #3572
turbowop's Avatar
Originally Posted by macke
If you buy real quality electrical tape like the Scotch Super 33+ you will have no problem reusing the tape. It's thin, stretchy and heat resistant.
I use that stuff everyday at work since telecom infrastructure is my career. I would still rather use velcro, but that's just me.
turbowop is offline
Old 06-22-2011 | 08:15 AM
  #3573
bronc4now's Avatar
Originally Posted by JEFFs SC10
I dont understand why you have to tighten the slipper down that much
I did that because I thought all the slipping was causing heat I looked at pads and they were shiny but not galazed I don't think maybe I'm wrong.. I just could tell when I hit the gas it had lag ,like. There's no way I could do a wheeliy
bronc4now is offline
Old 06-22-2011 | 08:35 AM
  #3574
bronc4now's Avatar
Steve
Thank u ,ill buy high and low but I'm glad to see im not the only one going low
Old 06-22-2011 | 08:45 AM
  #3575
JEFFs SC10's Avatar
trial n error is the best way to figure it out.
JEFFs SC10 is offline
Old 06-22-2011 | 09:11 AM
  #3576
jojo97's Avatar
my truck get a lil ass happy what can i do to fix this?? thanks
jojo97 is offline
Old 06-22-2011 | 09:22 AM
  #3577
Rick Hohwart's Avatar
Originally Posted by Pktdominic
Well it pains me to say this but hopefully by doing so I will save someone some of the same frustration I have had and hopefully will get some response from AE. First let me say I have bought almost ever type of kit from them from onroad, oval, truck, 18T, buggy 4wd buggy, sc, sc4wd and up to this point have loved every minute.
I built the kit and although had to make several adjustments with the drimel wasn't upset bc all my parts were there and I would have rebuilt the diffs and shocks anyway bc thats just how I am...I enjoy building the kit and knowing what I have.
Well the 1st weekend after buying the truck 2 days after its initial release I broke a rear shock tower coming off a jump...was it my fault...sure it was...was it a shotty custruction or kit, no...well I say no I only have 2 minutes of run time, but the kit seems solid.
So where is my problem, well I cant get a shocktower...heck I can't even get a call back from AE...I just have to keep calling till someone answers. Everyone is backorderd becasue they haven't released parts...I understand that they wanted to get the kit out, I really do but this is really poor planning and customer support and should have been rethought.
So why after weeks of waiting...calling and sitting waiting while others race am I posting? Because upon calling today after leaving to 2 messages regarding future parts availability, I finially get to talk to someone who says parts will be in next week...which is great...but wait...AE is closed next week due to inventory...they will be accepting the delivery and not sending out to distributors or selling for another week. This did it I am done with it...all I want is a part...I have spent $1000s on AE kits, electonics, batteries, and parts, been a loyal customer and this is what I get. My $1000s may be nothing compared to what some spend but for me it has been what I could spend and I chose them. Well no more...make it right or loose me forever I am done...I don't want anything for free just to be able to buy a part for the kit I bought from you so I can enjoy it maybe some follow up. If you have parts coming in you should make an exception and get them out. Your customers are what makes you. You are wrong.
Dominic
I have a shock tower for you. Please PM me your mailing address and I will send it today.
Rick Hohwart is offline
Old 06-22-2011 | 09:37 AM
  #3578
Farmer_John's Avatar
Rick, you rock.
Never had any problems with ASC. CS. Don't think I ever will.
That's why I'm a Team Associated fan boy...
Farmer_John is offline
Old 06-22-2011 | 09:44 AM
  #3579
20 SMOKE's Avatar
need a little more info
loose,bounces around on small bumps,kickes up off a jump,ect
20 SMOKE is offline
Old 06-22-2011 | 09:47 AM
  #3580
Robotech's Avatar
Well, got the body painted and mounted...
Now my only question is where to put some holes to reduce the "parachute" affect? Tonight will be finishing that up and then rebuilding diffs/shocks.
Robotech is offline
Old 06-22-2011 | 09:53 AM
  #3581
Truck looks good- Id like to see some pics of it when you have cut the holes out.
beenaround is offline
Old 06-22-2011 | 09:55 AM
  #3582
20 SMOKE's Avatar
that looks good,i would like to see one reverse colors
20 SMOKE is offline
Old 06-22-2011 | 09:56 AM
  #3583
Wild Cherry's Avatar
Default Fresh from Milwaukee
Ft shocks ( no bladder)
40W 1.3 piston
7000w in ft diff & 5000w rear
Rear shock( no bladder)
32.5W 1.3 piston
battery forward
lock up clicker
under-drive pulley up ft
Lrp 4.5 550
11T pinion
Wild Cherry is offline
Old 06-22-2011 | 09:59 AM
  #3584
Robotech's Avatar
I'm open to suggestions. I hear people using dremels to do them but what bit do you use? Also, how big should they be? I've seen some real small and others where they've put in a whole bunch of holes along the base of the windshield.
20 Smoke, I'm more of a black car guy than a white car guy but it would be easy enough to do...the "CAT" logos are all painted on so you'd just reverse the black and white.
Robotech is offline
Old 06-22-2011 | 10:12 AM
  #3585
Originally Posted by Cameron Kellogg
Also good to have when eatting to many hot dogs at the track.
Welcome back.
T
Good news
Just got BK's set-up for 2w & 4w Sc 10...
The 2w set-up is all new with sway bar's , hear its very dialed...
Will be sharing later this week after I put it on.
