RC10B4.1 FT/WC
Old 06-06-2011 | 04:34 PM
  #3076
mellow's Avatar
The new chassis doesn't have a mold plug in the bottom either, so if the chassis has that its an older b4 chassis.
mellow is offline
Old 06-07-2011 | 06:10 AM
  #3077
Quad Racer 34's Avatar
Can someone post a link for me of shims I need to shim a arms and other things for when the car creates slop? Thanks.
Quad Racer 34 is offline
Old 06-07-2011 | 06:12 AM
  #3078
racer1812's Avatar
Super Moderator
Originally Posted by B.A. Racer
the b4.1 has taller sides to hold the larger lipo battery packs..that what ive heard..im to lazy to actually measure it but they are pretty much the same
I'M too lazy to measure either but I've never heard of this so until my laziness fades I'll believe this is not correct
racer1812 is offline
Old 06-07-2011 | 08:40 AM
  #3079
Matt Trimmings's Avatar
Just go to amain and search shim...used to always use the shims that trinity/reedy would sell for electric motors, I believe they were 1/8". I know Kyosho sells 3mm shims, those would work too.
http://www.amainhobbies.com/product_...3x5mm-Shim-Set
http://www.amainhobbies.com/product_...Motor-Shim-Kit
Matt Trimmings is offline
Old 06-07-2011 | 08:55 AM
  #3080
aeRayls's Avatar
I believe shimming the arms really doesnt help much at all. With the new plastic all the hinge pin holes in the arms get egg shaped a slop out side to side.
I find it much easier to to just spent about $15 for new front and rear arms and caster blocks. Maybe another $3 on the inner hinge pin set. Then just replace the black washers on the steering knuckle and new ones at the rear hubs.
aeRayls is offline
Old 06-07-2011 | 09:35 AM
  #3081
Jmuck69's Avatar
http://www.xfactorystore.com/storeDDP.htm#torx
Look at first item on the page.
Jmuck69 is offline
Old 06-07-2011 | 09:52 AM
  #3082
Thank you
Old 06-07-2011 | 12:53 PM
  #3083
Default Newbie in the RC world
Hi,
Just got a B4.1 RTR, really excited to be back in the world of RC after 20 yrs. Had a Kyosho optima mid back in the 80's...
Naturally, now I'm looking for lipo batteries and charger to get started. Any recommendations? Friend of mine is running Hobby people's 7.4v 35c lipo on his slash are they decent enough for a beginner to run?
Thanks!
GuiltyByAssoc is offline
Old 06-07-2011 | 01:03 PM
  #3084
Asharus's Avatar
I personally have 3 SMC 24C batteries 1 of them 4100mah and the other 5200mah and one Dynamite 25C battery 6000mah. The 17.5 SC spec class at my local track calls for 25C max which is the reason I don't run anything higher than 25C. My 2 chargers are a Common Sense AC/DC balance charger and the Venom Pro balance charger. I run these on my B4.1 (13.5) and SC10 (17.5).
Asharus is offline
Old 06-07-2011 | 01:21 PM
  #3085
^^ Thanks! checked out those, wow didn't know batteries and charger will cost the same (if not more) than the car itself...this is going to be expensive.
Old 06-07-2011 | 01:27 PM
  #3086
Jmuck69's Avatar
It is actually cheaper in the long run. You can get away with one lipo for a club race day. You do not need the endless number of NiCd batteries of yesteryear. One lipo for practice and racing. Lipos are a god-send when it comes to RC racing along with brushless motors!
Jmuck69 is offline
Old 06-07-2011 | 04:12 PM
  #3087
Asharus's Avatar
Yes, you really only need 1 pack per car but I like to have a spare ready just in case.
Asharus is offline
Old 06-07-2011 | 04:45 PM
  #3088
mellow's Avatar
If you spend a lot of time at the track for practice days, you'll appreciate having two packs, but 1 is all you really need for race days.
mellow is offline
Old 06-08-2011 | 12:45 PM
  #3089
Default mods for the b4.1 any ideas ?
i tried searching for this but i saw once while back about cuting the rear brace down to make it flat on the chassis is this a mod that is commonly done or was i reading somthing else?
Eastcider is offline
Old 06-08-2011 | 01:02 PM
  #3090
Jmuck69's Avatar
You might be referring to the the new C towers for the FT rear hubs. It lowers the roll center of the rear to give more traction w/o taking away steering. There is a 2mm raised portion on the rear brace that has to be ground smooth and level to the surrounding brace. This along with the C tower will lower the the rear camber link 2mm.
http://www.teamassociated.com/factor.../details/9873/
Jmuck69 is offline
