RC10B4.1 FT/WC
#3061
I run on indoor clay and they definitely dont start working til they break in but once you get to that point they perform pretty well
#3062
#3063
better off getting a t4...the only parts that you can use off your b4 is basically the steering/front bulkhead and the tranny/rear pivot. You would need to buy arms, driveshafts, shocks, chassis, shock towers...etc
#3064
track isnt dusty unless we dont sweep for the day, hard packed and almost similar to a clay feeling when nice and wet at nite time. Double dee green compound should work well according to maifield the the track is hard packed and dry or wet and loose. IDK ill get back to you guys on that.
#3066
That will work fine if you want to try it. the main difference between a t4 and t4.1 chassis is the material.
#3068
Edit: got beat to it lol
#3069
#3070
#3073
B4 Chassis -vs- B4.1 chassis
Are there any differences beside material in the 2 chassis?
I found B4 chassis on-line but not to many B4.1. Don't want to go the T4 route, just had a body painted not to long ago.
#3074
It is probably a b4.1 chassis. The part number didnt change with the .1, it was a running change. ASC9560 is the part number.
