Like Tree13Likes
Murnan Modified Motors
Old 05-23-2011 | 07:59 AM
  #2851
Grinder's Avatar
Originally Posted by picco007
Thank you Uriah. Once you find out about the RB2668, let me know. I also have a t10 rc that I got from a buddy and wanted to know more about what pipe would work for that motor.....I would think the ones we've talked about would be the way to go unless you have another one you would recommend. Let me know your thoughts.
Ronnie
I will let you know when I test the pipe this weekend. I know my drivers that attended the Euro's a couple of weeks ago told me that the 2668 was the pipe to have. Most of the RB engines were running it. I was told it made gobs of power, and decent runtime.
Grinder is offline
Old 05-23-2011 | 08:11 AM
  #2852
picco007's Avatar
Thanks, let me know!
picco007 is offline
Old 05-27-2011 | 04:56 PM
  #2853
Default RB .12 mod
RB .12 mod What would be the different in gearing for this motor coming from a nova flash .12???
jorge858 is offline
Old 05-28-2011 | 04:45 AM
  #2854
Grinder's Avatar
Same gearing should be fine.
Grinder is offline
Old 05-29-2011 | 09:35 PM
  #2855
bassman2's Avatar
Default Murnan modified 35 plus 21
I just came back from the 34th Annual Texas Biggie. I participated in the 1/8 GT class. My engine of choice was Murnan modded Novarossi 35 plus 21. All I can say is WOW!!!!!!! What a beast. The engine screams at low end and top end. I was able to TQ'ed after 6 qualifiers. Although my car was not able to finish the race due to an unfortunate push into the wall by other cars and broke in the 45 min. A-Main, however first ten minutes into the race I was already 2 laps ahead of 2nd position driver. Thank you Uriah for a superb modded job and a wonderful engine.
bassman2 is offline
Old 06-07-2011 | 01:08 AM
  #2856
Default Broken rod
Hi Uriah!
On My last race the rbm3's rod 's broken.so please give me advice,
The engine is 1 year old it has 8 race, the problem is not just the rod, the bottom of the piston broke, the bottom of slave pushed. As i saw the crankshaft is fine but the crankshaft pin has a little bit different dimension already.
I can measure .02 mm different from other direction, so is it right or out of tolerance? The bearings are fine yet , so is it enough to buy a new pis/sla/rod set or a complete new engine .
Thaks!
Chrys
Chrystoforo is offline
Old 06-07-2011 | 03:16 PM
  #2857
Murnan Picco Torque
Vector03cobra is offline
Old 06-07-2011 | 09:42 PM
  #2858
Blue Screw's Avatar
hello i have been trying to contact mr murman.. i sent some emails through the site and i just sent one to an yahoo email... please contact me [email protected] im interstedin some motors
Blue Screw is offline
Old 06-08-2011 | 03:54 AM
  #2859
Grinder's Avatar
Originally Posted by Chrystoforo
Hi Uriah!
Thaks!
Chrys
Hi. Usually if the rod breaks the engine block is damaged. If the block, and crankshaft are ok then you can rebuild it. That crankshaft pin is within tolerance.
You can send the engine to me for inspection to be certain that everything is ok. Sometimes when that happens the crankshaft can get slightly bent.
Grinder is offline
Old 06-08-2011 | 05:17 AM
  #2860
Grinder's Avatar
I sent a reply. Please check your spam filter. You can call me to discuss if you prefer. 770-378-9669
Grinder is offline
Old 06-08-2011 | 05:58 AM
  #2861
Murnan 21-35 Motor takes win at Round 2 of the Midwest Series.
Portage Indiana.
Motor setup
24 Head clearance.
8mm Venturi
Max 6 Plug
16% VP fuel
Total time on motor 2.5 gallons
Vector03Cobra (Jeff Zuccarell) Below First Place (Black Car)
Gota Thank the Pit man Marvin Davis
Old 06-17-2011 | 12:38 PM
  #2862
Blue Screw's Avatar
hey guys not only is murman the man when it comes to moding.. but hes great with service also.. i call and order on wed and had me a fresh built mot on my door by fri for my race..... thank yyou very much i look forward to winning and promoting u very much
Old 06-18-2011 | 06:53 AM
  #2863
uriah, Is the P/s set for the RB T10 and T10 rc the same. Have a RBT10 Rc but your site list just RB T10 set. Thanks. Also what plug recommendation for this motor for hot humid weather in the south.
JETT is offline
Old 06-19-2011 | 04:16 AM
  #2864
Grinder's Avatar
The P/S sets are not the same. The RC has more exhaust timing. The standard t10 P/S set will work just fine in the RC though.
For hot, humid weather use either the c7tgf, or the c6tgf nova plug.
Grinder is offline
Old 06-26-2011 | 05:17 PM
  #2865
Uriah, which one of your modified P/S sets would you recommend for my RB10 RC?
Some novarossi sets work also, right?
JETT is offline
