Like Tree12Likes
Murnan Modified Motors
Old 12-20-2021, 04:04 AM
  #3841
HK500Pilot's Avatar
Default Mephisto .21 Murnan - Part Needed
Hello folks looking to see if someone could direct me to the correct person or business that would be stocking parts for this engine? All I currently need at this time is the part that slides over the motor shaft and when the flywheel is slid on this part is pinched closed and it holds the flywheel in place. I apologize for not knowing the correct name of this part. The paper that came in the box with the engine that shows a blown up image of the engine shows this part I need as Part # 20000.
Thank you in advance for any help that can be sent my way.
HK500Pilot is offline
Old 12-20-2021, 06:23 AM
  #3842
Roelof's Avatar
These cones are pretty standard so go to your LHS and see if they have one. If you have an old engine you can use that one.
Roelof is offline
Old 12-20-2021, 07:06 AM
  #3843
HK500Pilot's Avatar
Hey there thanks for the reply......unfortunately I don’t have an LHS. I’m completely forced to buy online. Also, I do not have an engine that is not currently being used. All the engines I have are installed in vehicles. What is the proper name of this part so I can ri some searches for it?
Thanks for the help!
Old 12-20-2021, 07:32 AM
  #3844
Cant drive's Avatar
Flywheel collet is what you’re looking for
davidl likes this.
Cant drive is offline
Old 12-21-2021, 01:39 PM
  #3845
HK500Pilot's Avatar
Thank you very much for the reply!
Old 12-21-2021, 05:03 PM
  #3846
HK500Pilot's Avatar
Thanks for giving me the proper name for this part. I ordered a couple and have them on the way to me.
