Like Tree2991Likes
1/12 forum
Old 05-11-2011 | 12:35 PM
  #35881
taken From my 1/12th Bible
"tire split Difference between front and rear tire diameters)
- is pretty useful for tuning steering characteristics.
Larger split - more rear grip, less turn in.
Closer split - more turn in, free rear end.
2 - 3mm of split should be a pretty common number."
jdeadman is offline
Old 05-14-2011 | 04:27 AM
  #35882
TRF4evr's Avatar
Default 3.7 1S battery
has anyone tried using speed power's 6000mah 65C 1S battery?....anyfeed back much appreciated tnx in advance.
TRF4evr is offline
Old 05-14-2011 | 07:27 AM
  #35883
I was wondering if a 35 amp hobbywing xerun would work in 1/12 for 13.5 no boost (1cell)? I'm looking for a cheap esc I can put in the 1/12, but also use in my SC truck if I need to. Any input is appreciated.
oceanhighz is offline
Old 05-15-2011 | 01:04 AM
  #35884
Default Speedpower 1s 6000mAh 65c Feedback
All I can say is, Awesome!!!!!!!! Very nice lipos indeed and you cant beat the price if buying direct off the Speedpower website.
Bumpy is offline
Old 05-15-2011 | 04:54 AM
  #35885
UltegraSTI's Avatar
well after 20yrs since i last ran 1, i'm back in the 1:12 game. walked out the store with a 5.1 yesterday along with some trick bits to finish it off. i bought 74T spurs as they were the shortest they had but i've heard/seen mentions to even smaller spurs. there is talk of doin 17.5 during the wk for a more relaxed setup oriented race nite and its gonna require some serious gear. checked nexus, stormer, and ST-no luck. thoughts/info? thx
R
UltegraSTI is offline
Old 05-15-2011 | 06:10 AM
  #35886
Ryan,
I'm actually looking for the same info as you, and if I find anything I'll let you know. What else did you get to finish off the 5.1? I'll be running one at MRH as well... Currently looking for a 13.5 setup (Cirtix is what they have, so I think I'm gonna go that way since there is no boost). Just trying to figure out what else may help.
Brandon
Old 05-15-2011 | 08:47 AM
  #35887
JayBee's Avatar
Guys, check out Jason @ BMI.....he should have you covered. Or PRS (Precision Racing Systems). Both have top-shelf stuff.
JayBee is offline
Old 05-15-2011 | 09:29 AM
  #35888
303slowdown's Avatar
You really shouldn't need anything smaller than that (I'm assuming 17.5 blinky) a roll out of 4.0 should be ruffly what you need and I can get that with a 76 spur 58 pinion and 1.69 tires (smaller pinion if you run bigger tires). Theirs really no need for a smaller spur.
303slowdown is offline
Old 05-15-2011 | 11:14 AM
  #35889
The new CRC spur gears are great! Lots of diff holes for an even smoother diff. Though with the smaller diff ball you will need to space your axle to compensate. Their gears go down to 72T.
http://www.teamcrc.com/crc/modules.p...prodID=7719176
InspGadgt is offline
Old 05-16-2011 | 09:14 AM
  #35890
UltegraSTI's Avatar
reading the instructions for my 12r5.1 in anticipation of goin home and buildin her 2nite. however i noticed it says the supplied servo saver is an airtronics. well i use futaba. in the picture it doesnt look like a SS with inserts-just a standard kimbrough-esque unit. so does that mean i have to go to the hobby store and pick up a futaba servo saver? kinda dumb move there if thats the case.
R
Old 05-16-2011 | 09:43 AM
  #35891
Yep. They designed the car with servo mount spacing for a Futaba, then include the horn for an Airtronics..
Serzoni is offline
Old 05-16-2011 | 12:12 PM
  #35892
"Back in the day" the preferred servo in 1/12th scale was the Airtronics 94145 servo. So most of the kits from that time forward were and are often still designed around that servo. Hence why it comes with an Airtronics servo saver. The servo savers that use an insert are usually too big for 1/12th and have a much stronger spring than what we need for 1/12th.
Old 05-16-2011 | 12:18 PM
  #35893
..and ironically enough, Associated's own servos take a Futaba horn.
(yes, I know they don't make a 12th scale sized servo, but still...)
Serzoni is offline
Old 05-16-2011 | 12:23 PM
  #35894
UltegraSTI's Avatar
well back in my day, pan car guys lived and died by the futaba S132H. heck many of them only servo taped them onto the chassis, sometimes with a horn. worst case u snapped the horn or popped ur servo off its tape. but most times w/blocks...the old days.
R
Old 05-16-2011 | 12:24 PM
  #35895
My younger brother's L4 is still rockin a S132H (hand-me-downs)
Serzoni is offline
