RC10B4.1 FT/WC
Old 05-08-2011 | 07:44 AM
  #2776
bds81175's Avatar
Moderator
Inboard toe has a much more substantial impact to the wheelbase.
bds81175 is offline
Old 05-08-2011 | 09:16 AM
  #2777
NightcrawlerRc's Avatar
Originally Posted by ZooB
i have a question about the AE setup sheets and rear toe.
i havent seen where they specify which rear suspension mount they use? is it implied that they are using the 2.5* unless otherwise stated? it always says what rear hubs they use, but never which arm mount....
maybe im blind but could someone help me out with this? thanks.
Originally Posted by mellow
The total toe is calculated by adding the toe block and the hubs, so if you're running .5 degree hub carries and a 2 degree toe block then you have a total of 2.5 for your toe. Hope that makes sense.
Originally Posted by PFKAOG
Wouldnt it be 3 deg toe total? .5 hub on each side = 1 deg toe plus 2 deg toe on the mount
No it wouldn't be 3 degrees of total toe, you only use .5 degrees once if you have them on both sides. with a 2 degree block and .5 rear hubs, the total is 2.5. You only count the toe on one side for your total degrees of toe in
NightcrawlerRc is offline
Old 05-08-2011 | 01:35 PM
  #2778
mini-t12's Avatar
Originally Posted by B.A. Racer
gearing on a b4 tekin 8.5 no boost...any good start points? good sized out door track
with my "no boost" lrp sxx and banzai 8.5, I am geared 23/81, this is my start and main gearing, I run on medium size tracks, hope this helps
mini-t12 is offline
Old 05-08-2011 | 03:39 PM
  #2779
I thought I had read in the past that more toe at the wheels gave you more traction but toe inboard was better for bumps? I too would really like to know the effects this has on the car? what would happen if I put a full degree or 1.5 degree at the wheel and 1.5 inboard?
I dont race on a typical track for todays standards... very bumpy dry and dusty and the jump layout is more designed for 1/8th scales.
gguertin145 is offline
Old 05-08-2011 | 05:02 PM
  #2780
CCristo's Avatar
Dan Griffin describes it well:
Originally Posted by DanGriffin
Changing the toe block changes the inboard toe. Increasing inboard toe in general provides more overall traction and makes the car more mechanically stiff. The downside of inboard toe is it can decrease cornerspeed.
Changing the outboard toe (hub carriers) is generally a mechanically softer change, and would be better suited for lots of sweeping corners. It also feels like a more subtle change.
The toe blocks also change the wheelbase of the car more than the hubs.
CCristo is offline
Old 05-08-2011 | 05:44 PM
  #2781
euromut's Avatar
Originally Posted by racer53
I really like the RPM cups over the stock ball cups...been using them for the last year...
They are great, Ive bent some to the point I replaced them. But never come close to breaking any, and they don't pop off regularly either.
euromut is offline
Old 05-08-2011 | 10:25 PM
  #2782
ZooB's Avatar
thanks so much! exactly the answer i was looking for!
ZooB is offline
Old 05-08-2011 | 11:10 PM
  #2783
CFR's Avatar
CFR
C4.1 Centro Mid Motor Conversion Kit B4/4.1
Wins at R2 of the UK Nationals
check put o0ple News
keep up to date with breaking news in this thread
CFR is offline
Old 05-09-2011 | 03:59 PM
  #2784
idrummerboy13's Avatar
Default b4.1 bite
hey guys my b4.1 with 0 degree hubs and 3 degree toe in block is a tad loose in some sections but amazing in others. would a 3.5 block help? ik i have to put in a long wheel base after... thanks
idrummerboy13 is offline
Old 05-09-2011 | 05:15 PM
  #2785
If you have a 2 degree block I believe that is total toe which would = 1 degree per wheel. Add on a .5 degree hub would = 1.5 degree per wheel x 2 wheels = 3 degrees.
I'm no mathematician so I could be wrong.........
Dang, where's Sour Cherry when you need him
PFKAOG is offline
Old 05-09-2011 | 05:22 PM
  #2786
Thinking of getting a B4.1. I don't want to read through hundreds of pages...
What are the weak areas of the car? I will be racing on a small/mid sized track. What are some immediate upgrades?
vstrok is offline
Old 05-09-2011 | 05:25 PM
  #2787
well buy a factory team and your set
Old 05-09-2011 | 05:30 PM
  #2788
B.A. Racer's Avatar
well i use the factory team turnbuckles but a lot of people use titanium so it doesnt break
B.A. Racer is offline
Old 05-09-2011 | 05:53 PM
  #2789
Matt Trimmings's Avatar
well i use the alluminum turnbuckles but a lot of people use titanium so it doesnt break
Aluminum turnbuckles??
Matt Trimmings is offline
Old 05-09-2011 | 06:09 PM
  #2790
vr6cj's Avatar
maybe he thinks the FT blue turnbuckles are aluminum?
vr6cj is offline
