8T 2.0
I've got some saved that someone else posted. I don't remember who it was though. uploaded at the bottom.
Note: Inclined parts are BLACK, standard parts are grey...
With the LRC rear end you would run 1's up in the forward block and 0's in the rear block. That would get you 3* of anti-squat and 3* of toe in, which is a pretty standard setup that most use.
If you don't know what caster does, download the file below. IMO this file is a MUST HAVE. Great info in there...
http://www.teamxray.com/teamxray/sho...p?file_id=4461
LRC stands for "Low Roll Center". The original adjustable plates raised the rear roll center by 1mm from the stock plates. The LRC plates lower the roll center back to what the stock plates provide, but allow you to adjust the toe and anti-squat angles.
Linky..
http://www.amainhobbies.com/product_...race-w-Inserts
Linky..
Linky..
Linky..
The reason for the LRC blocks is so that you still get the benefit of being able to adjust the angles as you please while also having the proper roll center for the inclined parts.
Hi
I am looking for a setup for realy bumpy track, what are your suggestions?
I am shortenig droop and increasing ride height, am I doing the correct thing or I am dooing something wrong?
Problem what I have is when I hit a bump it throws rear upwards.
I am using standart setup with shorter droop and higher ride height.
Thanks for reply.
Thanks for reply.
Hi
Thanks for reply.
Thanks for reply.
What is your current setup?
Linky..
Linky..
