Break-in procedures
#16
Originally posted by Q
how do you run the car (wot) on the track ? I can see doing it on a bench or starter box...
AFM
#17
Originally posted by GUNPOWDER
I would've thought that this would damage the engine as it (constantly) gets to really high rpms.. (even when the engine is fully run-in..)
AFM
#19
i'm not concerned about damage it just seems you would want it running at a consistant rpm not up and down..
AFM
#20
Ahhhh, this is hurting my head....
OK, so I did the heat cycle thing the first 2 tanks, keeping the engine running for about 3 minutes at around 220-235 F. I plan on hitting the street tomorrow to do some running. Now, should I hit it WOT, very rich, or baby it the first few tanks, gradually leaning and increasing throttle?
#21
#22
AFM
#24
Originally posted by edseb
Heh, and if all else fails and it works great and your buddy proves all the motor manufacturers wrong, then so be it. He'll change the whole motor industry and be the last one laughing. Just hope you're right, the RB motors aren't cheap. Just my two cents.
. Thankyou everybody for you input and hopefully I see some of you at the 1/8th scale on-road nationals in July. Goodluck.
#25
No, my comment was in relation to running WOT on the bench.
You have to set the HSN for the engine to be rich in 2 stroke and at the right temperature of around 90°C.
AFM
#26
Originally posted by afm
Don't be afraid, warm it well before running, and then WOT for 3 tanks rich 2 stroking, and then for the last tank start leaning and tuning for performance. BTW what engine are you Breakin- in???
AFM
AFM
Took it out for about 3 tanks today. First tank at about 3/4 throttle, easy on throttle (had rubber tires in my lot) then full throttle on the street on foams. I can tell already she's gonna be nasty. The temps are still under 235, so I guess I should start adjusting for performance in a tank or so. I'm trying to get it as close as I can before race day, since they set the track up in a lot that day and the small permanent track we have I can't get to at the moment
#27
Well the answer is still NO. The propeller that comes with the Break-In Bench puts a load on the engine that prevents it from going on to the high revs that the engine could reach, plus the rich mixture setting adds to not allowing high revin. Properly set the engine reaches the right revs for WOT Break-in.
AFM
AFM
#28
ANd well my answer too is still NO. I am talking about putting the car on the bench and going WOT!!! (read my response to the original message.. it was in response to putting the car on the starter box and going WOT)
You finish your Break-In process at the track with recomended procedures.
You don't WOT your car on the starter box, because it doesn't give proper load on the engine.
What some drivers that don't have a Bench do, is run-in the engine on the car with flywheel, clutch, and gears, over the starter box at a throttle position and rich mixture enough to get the engine to at least 90°C, and do the first tanks like that, and then finish the process at the track.
AFM
#30
That's exactly what I've been saying... Yes.. Read the posts..:
AFM
