RC10B4.1 FT/WC
Old 04-12-2011 | 03:04 PM
  #2356
mellow's Avatar
Originally Posted by Jmuck69
This is a pic of his car at the recent EOS race in Europe. He is not using the offset mount, because of the new motors.
New orion motors look sick!
mellow is offline
Old 04-12-2011 | 03:05 PM
  #2357
TheModTurtle's Avatar
Originally Posted by B.A. Racer
im talking about the little molding on the bottom of the tire so it just lays on the rim nice and neatly....idk but i want an easier way to glue tires nicely
I think I know what you are talking about. The part that gets glued to the rim right? Basically, try it out if it works then keep doing it Just try it with one set of tires and see how it goes. Just make sure you aren't cutting away too much of the tire when you do it!
TheModTurtle is offline
Old 04-12-2011 | 03:08 PM
  #2358
just trying to keep up with my Fantom motors GOOD LUCK!!! Does look pretty sick though...
Old 04-12-2011 | 03:10 PM
  #2359
mellow's Avatar
Im probably just going to order a new Epic D3 8.5
mellow is offline
Old 04-12-2011 | 03:14 PM
  #2360
Ewwwwwwww why save 5 dollars and get the epic version when you can spend the extra 5 and get FANTOM labeled on it? These new motors are pretty sweet though. Run waaaaaaaaaay cooler than the old motors and their KV ratings are SICK! You can get a 9.5 geared the same as an older 8.5 to run about the same speed. In stock the Duo3/Fantom Ion 3's are just dominating! Since they run so much cooler people are gearing the heck out of them.
Old 04-12-2011 | 03:33 PM
  #2361
mellow's Avatar
That's what Ive been doing with my 13.5. I feel like I could add all the timing the motor has and boost with the speedo and the thing would STILL be cool.
mellow is offline
Old 04-12-2011 | 03:47 PM
  #2362
Which 13.5 are you running? The Team Epic or the newer Orion? Unfortunately, there is no real 13.5 class around here Its either 17.5 or Mod.
Steering has a looooot of resistance on my B4.. Would it be overtightened or dirty? The screws by the bumper are stripped so I can't check it out yet but what do you guys think?
Old 04-12-2011 | 03:55 PM
  #2363
euromut's Avatar
Originally Posted by onefast8
What is with the new 4.1 chassis? Didn't know I needed an impact to put the front three top plate screws in. Are people tapping/reaming these out at all?
Ive been using a 4-40 x 7/8 cap head screw to pre-thread all the holes before final assembly. Your far less likely to ruin a tool or strip a screw head that way.
That and I always run longer 3/4 screws through the bumper to the top plate anyway, to help keep them from ever stripping out.
Sounds like your servo saver has loosened up a bit, and is causing the screw to bind on the bearings/bushings. Tighten your servo saver bolt slightly, I bet it will free right up.
euromut is offline
Old 04-12-2011 | 04:00 PM
  #2364
mellow's Avatar
I've got the Epic 13.5 in my buggy, and a brand new orion in its box. That's how it is where I race, so that's why I'm going to get an 8.5.
mellow is offline
Old 04-12-2011 | 04:17 PM
  #2365
Thanks for the tip
So just switched from Mod to Stock because my local ST class died out... What would be a good gearing to start from for a 17.5?? I believe the class will be w/timing but my speedo doesn't have it so assume I'm timing the motor
Old 04-12-2011 | 05:43 PM
  #2366
Is the plastic from the t4.1 rtr to the ftt4.1 different?
Just wondering if I am buying replacement parts on ebay if it matters.
Thanks!
gguertin145 is offline
Old 04-12-2011 | 06:04 PM
  #2367
racer53's Avatar
No, they are both made out of the same crap.
racer53 is offline
Old 04-12-2011 | 08:23 PM
  #2368
+1 on crap!!
But I believe the RTR uses plastic composite vs. the FT kit using graphite or something like that ish...
Old 04-12-2011 | 08:48 PM
  #2369
i1justin's Avatar
+1 on crap!!
The .1 Factory kits mostly come with plastic parts now
i1justin is offline
Old 04-12-2011 | 09:28 PM
  #2370
Really? I thought the FT kits always come with the carbon (not composite) options
