RC10B4.1 FT/WC
#1996
Now, the link didn't work for me. What Lipos were you picking up for your car? And you were running the 10.5 motor. Is this for a 10.5 class or are you doing mod? Will you be using boost from your tekin rs speedo?
#1997
Nice. Just remember if you are new to the scene then his set-up might be a little too aggressive for you to begin with.
Pic of packs (Mine have Deans connected):
#1998
Ah okay
Well, other than going easy on the throttle finger I don't know what else you would be needing in advice
The stock motor size is the 540 can. You have the gearing figured out for your buggy?
#1999
I do plan on getting new batteries eventually but should those work ok for now? Main concern was the outlet of the wires.
#2000
Sorry I meant what is stock turn for Buggy haha. Not yet. Ill find out the gearing it has on it now and see how it matches up. I have a bunch of spurs and pinions so I can get it figured out. Its a pretty small track with Stock Buggy Class drivers running 13.5-14.5sec laps.
Outlet not the best , try to find better as the wires will not last if you have to mash um inside the battery tray...
#2004
I would definitely recommend sport packs for now though. You should look in the radios and electronics thread for some battery threads and get some ideas on what is good. For 2wd buggy something around 40-50c with 4500+ mah would be perfectly suited for racing. Anything over that is just extra.
#2005
#2006
#2009
#2010
