#3739
#3740
so it showed, "Hobbywing V1.07-110119" IS the LCD firmware.
after you Click item it is Connecting to your esc ex "connecting FW 3.0_110211" is your esc Firmware
that's 2 Steps accessing hardware firmware.
#3741
#3742
#3745
V3.0_110125STOCK
the Throttle curved is different,
lighter acceleration at 0~50% throttle (boost area).
This one had already the 64°
but i did not pay too much on performance yet,
i found a bit bug, during first update of this firmware,
throttle is dead, forward and backward,
this is very unusual.
the next i recalibrate, once it's calibrated throttle active it self,
so quickly i turned off the esc.
twice calibration, the result the same, throttle active it self.
something is wrong.....
so i switch to old firmware v3_110119,and calibrate successful (no problem).
then again i returned to update V3.0_110125STOCK 3x&fail, then 4th successful.
then calibrate result successful.
that's the story i don't know what's wrong.
but untill now the V3.0_110125STOCK work's fine.
#3747
i saw sighting, it was green blinking light.
thanks for the dark, it is very clear, that it was happen that day.
and almost missed this one
and it was identified the scenario as switching to sensorless.
slowing down.
this is eventually happen when kicked.
i made restart by switching off and on the esc, returned to normal.
these need Michael to explain why..ASAP.
slowing down.
#3748
I had heard about the 518stock but never used it - so today i compared the 518stock with the 119Stock firmware.
Nothing too scientific here but hopefully it will be of some value to people.
Newcastle / Sugar Valley
Tamiya TB-03
Tamiya Kit Tyres
XeRun 60a / XeRun 17.5t
Intellect 2S 4000mah 20c
119 Stock
FDR 6.00:1
DDRS 9
#9 = 32
#10 = 18/0.1sec
#12 = 24
#13 = 3000rpm
#14 = 0.3sec
#15 = 250
Lap Time: 21.6sec
Tamiya TB-03
Tamiya Kit Tyres
518 Stock
FDR 6.00:1
DDRS 7
#9 = 21degrees
#12 = 8degrees
#13 = 3000rpm
#14 = 0.4sec
#15 = 300
Lap Time: 21.1sec
I can see what all the fuss is about now. The 518Stock just feels so much smoother than the 119stock.
However, I do think the 119stock has a lot more power / top end speed.
Tamiya TB-03
Tamiya Kit Tyres
119 Stock
FDR 6.00:1
DDRS 9
#9 = 32
#10 = 18/0.1sec
#12 = 24
#13 = 3000rpm
#14 = 0.3sec
#15 = 250
Lap Time: 21.6sec
Tamiya TB-03
Tamiya Kit Tyres
518 Stock
FDR 6.00:1
DDRS 7
#9 = 21degrees
#12 = 8degrees
#13 = 3000rpm
#14 = 0.4sec
#15 = 300
Lap Time: 21.1sec
#3750
According to sizheng, the way the turbo is released....
4Likes
How much timing could you put into that
