#3571
i like you M7H,
That's True Guys it's "60°" on version 3.0_110119
and what ever the timing is set to over 60 Steps ex:70, it's end is 60°
by completing the Priority it's the Boost first, or completing with the turbo if the full throttle is activated.
an excellent technologies that Michael build.
and Angelo have been showing the new 110211 (213)_STOCK Firmware
that it has "64°"
which is "4°" over timed than the theory 60°, it's a new secret.
that it has "64°"
If 119 actually had 60deg, then I would have fried my motor along time ago.
1224: 0-38 Degrees, Turbo 0-16 Degrees (I always run 8)
0119: 0-60 STEPS, Turbo 0-40 STEPS.
With 119 you can run a total combination of 60 STEPS. Now if you can run 60 Steps of Boost, and 30 steps of Turbo.. Then you could get close to your 60 degrees, but that doesnt seem to be the case.
Micheal has already stated here on RC Tech 38deg of boost is 54 steps, so, at best you are getting 40 deg of actual timing.
Cheers,
Shawn.
#3572
Didnt think that would slip past you, you are correct. However, I have run 75 degrees on a motor, and it slowed the motor down, and created alot of heat. I left the Novak at N (30) and ran the 46deg from the 1224 software, motor was dead slow, and created alot of heat. I should have probably run the overheat protection.. Oh well.
Shawn.
Shawn.
The V3.0_110119
is really 60°
The new firmware 110211 (213)_STOCK
64° is a different method.
#3573
Take the manual, and delete the word "Degrees" from the manual, and you have a more realistic explaination.
Cheers,
Shawn.
Cheers,
Shawn.
#3574
Irgo, maybe you could explain how the FW works in better detail then. You seem to have some sort of inside knowledge, about new techniciques of applying electrical current in some special fashion that defy's all logic, and re-writes the rules of physics.
I have some friends at the univeristy that might be interested in your theory, you could probably publish your own paper on the topic.
Shawn.
#3575
Shawn.
Shawn.
and it's Method is not out of the physics it self.
let it be Michael Secret's For a while,
#3577
I have not been able to find a true outlet that sells the Xerun stuff here in the US. I can find many places overseas and on ebay. Anyone have any suggestions?
Also was thinking of putting the Xerun 120amp in a SC10 4x4 with a 550 can motor (when the truck comes out). Will the 120amp version be able to handle this kind of application and does Hobbywing sell a 550 can motor series?
#3578
Shawn.
#3579
#3580
Cherry, did you get my PM a week or so ago?? Think I've convinced a few new HW drivers at the track today!
First time outdoors for a long while and the Xtreme's first run in 10.5. Really impressed and there's definitely some more scope for adjustment for it as I'm nowhere near up to correct tuning yet. Running on a long straight (60m) I noticed the car accelerate more towards the end, guessing I need to turn the start RPM down to utilise the boost more.
Really happy with the 119 software. More testing to come.
#3581
I followed this steps ... :
- First all connected selecting the 2-in-1 program box as device.
- Upgraded all.
- Next went to ESC as device.
- Upgraded all.
- Configured all to 508 version no turbo.
- Applied all.
thats it.
performance wise i think its STOCK, but i cant see the led blinking on neutral so im preocupied for technical check at race.
regards,
#3583
Hi all...I really need some help with 0119 120A v2.1..This is my first race with electric car and i need to now what is wrong with my settings.My car was very fast at the straight but in chickenes no power.Also in 6 min i have a loss of power(7min race)I run with xray 09 with 43t/20t pulleys 84/27 and my settings are MOTOR 10,5 NOSRAM STORM EVOLUTION/NOSRAM 5300/40C
4)DRRS 6
8)6%
9)45
10)12
12)30
13)9000
14)0,3
15)400
Thanks for advance and sorry for my english nice forum by the way........
be good i m niewbe.
4)DRRS 6
8)6%
9)45
10)12
12)30
13)9000
14)0,3
15)400
be good i m niewbe.
#3584
#3585
4Likes
