Like Tree195Likes
Novarossi engines thread
Old 02-21-2011 | 04:28 AM
  #3901
The special was the standard 2010 edition which had the CNC piston instead of the microcasted. The tuned has a more advanced timing. I have seen both 2009 models and the tuned has a 1 degree shifted opening in the crankshaft and a 0.3mm higher exhaust port compared to the standard.
Roelof is offline
Old 02-21-2011 | 05:17 AM
  #3902
Riketsu's Avatar
In English please, for those who don't speak in degrees/mms of ports...
What would that translate in terms of power and power band??
Riketsu is offline
Old 02-21-2011 | 05:30 AM
  #3903
That would give you a faster spooling motor. Higher exhaust port=higher top end rpm!!!!!!!
HoboShop is offline
Old 02-21-2011 | 05:50 AM
  #3904
Or else it won't be called "tuned".
Yep, Someone explained to me the tuned had a more advance timed crankshaft but from what I have seen they are nearly identical. But Novarossi is changing specs from time to time and not telling us so I can not say something about the 2010 models and even from what I have seen is for sure not for all 2009 models delevered.
In simple words, the Flash is fast and the flash Tuned is faster, it is set for more RPM. If it is noticeable for an avarage racer or if he can setup the gearing and the rest of the car for getting it out of the tuned version is another question.
Roelof is offline
Old 02-21-2011 | 06:09 AM
  #3905
Thanks for clearing that up! I was thinking of getting a flash tuned as my next motor. I was looking at a kangaroo or a picco p7r edo modified but think I may spend the extra cash and get a flash. Any thoughts? I heard the kangaroo has a fragile liner and can crack if run to hot. Is this true?
JIM1 is offline
Old 02-21-2011 | 02:34 PM
  #3906
Originally Posted by kurtcash
hey everyone
i bought a 35 plus 21 pre run in engine. nib. off an ebay store.
the engine blew up after 3L of fuel, because of a faulty front bearing.
i emailed novarossi to discuss this issue of manufacture, and to discuss waranty.
they have subsequently put up on their website that no waranty will be given, if the engine was purchased from anyone on their distributor network.
so people beware.
What is your name? where do you live? I'm the USA importer and you haven't contacted us. I don't know the details but your story doesn't sound right.
jdesoto is offline
Old 02-21-2011 | 02:37 PM
  #3907
Originally Posted by jelayne
Besides the price I am seeing is there any noticable performance difference between engines with both ceramic bearings as opposed to just the rear ceramic like in the case of the PT and PTS ?
Mr. Rossi himself says the 'S' version is about 300 RPM faster.
jdesoto is offline
Old 02-21-2011 | 02:43 PM
  #3908
Not true. The Kangaroo is a workhorse! There is a reason why a 5+ year old motor still sells well. You can't go wrong with a Kangaroo, terrific value. Not the fastest Nova but faster than most motors from other brands.
jdesoto is offline
Old 02-21-2011 | 02:46 PM
  #3909
Serpent-Dan's Avatar
+1 the Kangaroo is the best value on the market!!
Serpent-Dan is offline
Old 02-21-2011 | 03:12 PM
  #3910
Phil Trotta's Avatar
I think with the new pricing the best deal is the xl7 from novamax kangaroo based 7 port tuned by massimo.
Phil Trotta is offline
Old 02-21-2011 | 04:30 PM
  #3911
Both great engines as they hold the same base. Not sure on the price of the Max but a 2010 spec Kangaroo can be found for 350 still @Kamikaze
Old 02-22-2011 | 12:46 PM
  #3912
anyone use this motor? if so, what kind of fuel are you guys using for weekend racing? thanks.
Ghett0 is offline
Old 02-22-2011 | 01:08 PM
  #3913
bfong13's Avatar
16% nitro (Byron's)
bfong13 is offline
Old 02-22-2011 | 02:18 PM
  #3914
Ok, so how would the Kangeroo compare with my Mega ZX21 DS2 EM? I understand it is a Picco based motor and is also a few years old now.
JIM1 is offline
Old 02-22-2011 | 02:44 PM
  #3915
It will be alot more reliable!!
