RC10B4.1 FT/WC
#1456
#1457
#1458
I think its been posted before and I measured it and its true: The new B4.1 standard rear arm carrier (the part that adjusts toe in) has more slightly toe-in than the old B4 standard block even though they are both supposed to be 3 degrees.
If you get a B4, I would recommend getting the B4.1 rear block system first and try the 3.0 block. If that doesnt resolve the loose on power feeling, I would suggest the .5 rear hubs.
This is the new part:
http://www.amainhobbies.com/product_...t-Set-25-335-4
Lastly, you may also want to invest in the ballast weight that fits in front of the transmission.
#1459
Actually, I've already added 49 grams of weight back there(I'd read about other doing it a wee or two ago), & have been working on shock mounting angle(& shock damping) & roll center adjustments, as well as playing with the length of the rear camber link(& it definitely IS helping, but I just feel like I need a bit more), so it would seem that toe angle is about the one thing I haven't tried....
#1460
I picked up the "B4.1 Rear Ballast Weight" (pn: 7488) but it doesn't say anywhere on the package nor the bar exactly how much weight it is. Does anyone know? Cavalieri's setup calls for 1/2oz in that position (under the rear shock mount) so I'm hoping that's how much the ballast weight weighs.
If any of the AE guys are reading this, you might want to pass it on to whoever does your packaging that they might want to add a detail like this. It's not even mentioned in the little folded-up instruction manual that comes with the part.
Thanks!
Thanks!
#1465
I talked to AE about this and they said that this is common and that their engineers are aware of it.
The only thing I noticed that you have to do to the old chassis, is take a file to the sides of the front kick-up so that the front arms move freely.
#1468
I've heard rumor that there are small air bubbles in the molds and if enough of them are concentracted in the weakest spot it can cause a chasis to break.
For those who have broken chasis, did you notice any?
#1470
Hey guys, looking for ideas for gearing in my new FTB4.1 and FTT4.1
I am running a Tekin RS w/ boost and a 17.5, 5000mah battery
I was thinking of starting at 26/75, is this a good starting point?
