Engine Bearings...... Which company?? >
Old 01-28-2011, 01:01 AM
Sein's Avatar
Default Engine Bearings...... Which company??
It is time for me to replace my engine bearings and was wondering which company to go with?
TKO or Boca? This will be my first time replacing engine bearings so I just wanted some insight from you experienced guys. Thanks
Sein is offline
Old 01-28-2011, 01:54 AM
shanty140's Avatar
My recommendations would be TKO.
shanty140 is offline
Old 01-28-2011, 02:13 AM
Rampokker's Avatar
I've used TKO on 2 of my engines (only due to amain having only those in stock when I ordered) and they performed great. I put around 3 gallons through each motor after the change, and they're still going strong.
Rampokker is offline
Old 01-28-2011, 02:43 AM
dishsoap's Avatar
TKO bearings all around are awesome.
Although I have never had to replace an engine bearing I do use the TKO bearings for wheels, diffs, and clutch.
There special clutch bearings are the bomb. I have never had one fail not once. In fact I have never had one even get gritty or close to failing.
After about 3 gallons on the clutch I change the bearings out just to be safe but dang even at 3 gallons I can spin the bell by hand and it keeps going and going.
dishsoap is offline
Old 01-28-2011, 04:09 AM
cary's Avatar
Trader Rating: 67 (100%+)
TKO or Boca? This will be my first time replace engine bearings so I just wanted some insight from you experienced guys. Thanks
Boca
they are a little bit more money but you get what you pay for
would have said TKO but had two rear ones go bad at
the loss of a bad ass moded O.S..28 and the win.
cary is offline
Old 01-28-2011, 04:16 AM
Trader Rating: 53 (100%+)
TKO Hands down! Used both and both were good but quality and price mad TKO the choice for me!
janderson78 is offline
Old 01-28-2011, 04:59 AM
l3asher's Avatar
l3asher is offline
Old 01-28-2011, 05:45 AM
gabor szilagyi's Avatar
Trader Rating: 12 (100%+)
TKO
gabor szilagyi is offline
Old 01-28-2011, 05:56 AM
"Smiley"'s Avatar
Trader Rating: 171 (97%+)
I have 2 engines with Avid Ceramic's in them. They work flawless, Zero leaks from the front bearing. Super Smooth. www.avidrc.com
"Smiley" is offline
Old 01-28-2011, 06:50 AM
Trevor Williams's Avatar
Trader Rating: 207 (100%+)
TKO
I cant say enough good thing's about TKO and Peter Martin. Peter is a stand-up guy who has outstanding customer service....he is a VERY knowledgable man that is very polite and helpful as well.......A+ guy and company IMO.
Trevor Williams is offline
Old 01-28-2011, 09:10 AM
Sein's Avatar
Thanks everyone! Looks like TKO is the winner.
Sein is offline
Old 01-28-2011, 09:15 AM
token's Avatar
For engine bearings I like boca, just feel better paying alittle extra for bearings I THINK are of a higher quality. Avids for all other.
token is offline
Old 01-28-2011, 09:17 AM
Sein's Avatar
Have you tried TKO?
Sein is offline
Old 01-28-2011, 09:19 AM
token's Avatar
Have you tried TKO?
Yes! Nothing bad to say. Their special Losi Clutch bearings are not bad at all.
token is offline
Old 01-28-2011, 09:25 AM
Sein's Avatar
I was just referring to engine bearing but what makes you pick boca over tko?
If you don't mind explaining a little
Sein is offline
