Novarossi parts ???
Hi does anyone know where I could get a centre clutch bolt (holds the clutch on to the crank) from for my Novarossi MR 12 thanks.
Also could anyone advise me where to buy parts such as pison from cheers - James
what car? I don't know if all cars use different clutch nut thickness?
Let's start there or like lil-bump said local hobby shop if your close to one....
Billy
Cheers but my local hobby store doesn't stock the parts. It Is a Nova MR 12 for a Mugen MTX4/R .12 1/10 IC. It is the Allen head bolt that holds the clutch bell on to the crank via the centre of the shoes. For the parts I was wondering if there would be a good online store ?
Cheers - James
Cheers - James
actually i think it has some sort of special spacing on it. Like a counter sink that caries on a short approx 6 mm spacing shaft type thing. But if it is removable then yes it is just a normal bolt.
cheers
Also does anyone know where to get A. the bearings for the clutch and B. main bearings (for the crank) and does anyone know the size of the inner bearing (the one closest to the con rod) cheers - James
cheers
By the way (if it helps) I think the main bearing closest to the clutch is 607Z what ever that is. Could the inner one be the same or different, by the looks it is slightly bigger.
