Tamiya mini cooper >
Tamiya mini cooper
Like Tree295Likes
Tamiya mini cooper
Old 01-21-2011 | 07:53 PM
  #14236
BumFacedGoat's Avatar
did you think of actually just trying what the locals suggested?
it looks pretty much spot-on from what my experience.
BumFacedGoat is offline
Old 01-21-2011 | 08:01 PM
  #14237
tony gray's Avatar
Originally Posted by 2-Bad
Caltek1,
Yeah I looked through that site but couldn't find any setup's specifically for the M05...
Ummm.... THIS gives you springs, shock oil, pistons, ride height, toe-in, etc etc. Specifically for the M05...have I missed anything?....
tony gray is offline
Old 01-21-2011 | 09:01 PM
  #14238
2-Bad's Avatar
BumFacedGoat,
Yes but as I posted I'm questioning it as most setups I've seen (for the M03) are running heavier fluid. As I posted I'm looking for reassurance.
Hey Tony,
Yes I read through that but I'd probably rate SA as med - high grip and hence discarded it. Where as the track at Keilor I've heard would probably best describe the track here.... (low grip, hairpins x 4, sweeper x 1). Would you not change anything from SA to Keilor?
thx....
2-Bad is offline
Old 01-21-2011 | 09:11 PM
  #14239
I)arkness's Avatar
i can give you a setup i ran this morning at keilor if you want, for an m05? i was running the rides and crosses though so not sure how it would go with the TCS specs tyres!!
pm me your email and ill give you a setup sheet.
I)arkness is offline
Old 01-21-2011 | 11:50 PM
  #14240
caltek1's Avatar
2-Bad,
I would use the USA TCS winners mini setup from the Tamiya site. I am sure Brandon would not mind. If you need the pdf file then PM me a E-mail address, as I can not post as too large to upload.
caltek1 is offline
Old 01-22-2011 | 01:14 PM
  #14241
Does the M06 pro come with zero degree rear toe hubs? That might be a handling problem out of the box.
rccartips is offline
Old 01-22-2011 | 01:25 PM
  #14242
monkeyracing's Avatar
M-06 has 1.5 degrees built into mounting plate for lower control arms. Supplied uprights are 2 degree. Total out of the box, 3.5 degree.
monkeyracing is offline
Old 01-22-2011 | 04:51 PM
  #14243
Monkeyracing, thanks. Maybe my friend flipped the hubs left/right and thought the car came with zero degree hubs.
Old 01-22-2011 | 05:43 PM
  #14244
over gear's Avatar
i just got a Manta Ray Ball Diff set for my M05. Which cone washers am I supposed to remove for a stiffer diff action?
over gear is offline
Old 01-22-2011 | 08:28 PM
  #14245
One of the small ones. Careful how much you tighten cause it can get too stiff. I used to do this but no longer do. If you're not a TCS racer, this works fine if you don't have to use the TCS spec tire. Not so great with the Spec tire.
Granpa is offline
Old 01-23-2011 | 08:17 PM
  #14246
SirSwiftAlot's Avatar
From: SOCAL the fastest mini cooper guys in the nation
M05 For Sale if anyone is interested.
http://www.rctech.net/forum/r-c-item...ml#post8535755
SirSwiftAlot is offline
Old 01-23-2011 | 08:20 PM
  #14247
Originally Posted by caltek1
2-Bad,
Of course I don't mind. If anyone has questions feel free to ask. PM is easier for me. Got the 06 at the Tamiya track on Sat. Its not where it needs to be yet but I am sure after several more track sessions it should come around. BTW where was that posted its the first I have seen it. I remember doing the interview.
Old 01-23-2011 | 08:41 PM
  #14248
silvermag's Avatar
hey guys,im trying tofind a lipo battery to fit the m03. that in legan to tamiya rules, does any one know and can post options, thanks.
silvermag is offline
Old 01-23-2011 | 10:42 PM
  #14249
Ran the M-06 for the first time tonight. (indoors on sticky carpet) Ran it pretty much box stock, including tires. It's a very forgiving ride, compared to the M-04. It doesn't seem to have the outright speed, though.
I used 0 degree uprights on the rear, only used the built in 1.5 degrees. It worked well. Kit tires and spring setup were good. Overall, I like it, especially when compared to the 05.
Jim
Old 01-23-2011 | 11:00 PM
  #14250
Morbo's Avatar
I keep forgetting. Is the Manta Ray or TA03 ball diff the one to have? Or is it the M05 one?
Morbo is offline
