8T 2.0
Old 01-20-2011 | 02:20 PM
  #11026
tc5 man's Avatar
Tech Prophet
did you guys see these
there for the 2.0 t there unversal axles.
Attached Thumbnails 8T 2.0-losa3587-450_thumb.jpg   8T 2.0-losa3588-450_thumb.jpg
tc5 man is offline
Old 01-20-2011 | 02:27 PM
  #11027
bigjayjay1's Avatar
Nice pin looks bigger
bigjayjay1 is offline
Old 01-20-2011 | 02:36 PM
  #11028
tc5 man's Avatar
Tech Prophet
well, i can say ive ran univertsals on my 1/10 offroad cars and there strong and theres no play in them at all so im guessing its the same for 1/8.
and there wear pretty good.
tc5 man is offline
Old 01-20-2011 | 02:54 PM
  #11029
guys im selling off my truggys there brand new
http://www.rctech.net/forum/r-c-item...brand-new.html
transplantlife is offline
Old 01-20-2011 | 03:27 PM
  #11030
JAMMINKRAZY's Avatar
Originally Posted by alexrckid
how many degrees(of incline) are the stock 8t 2.0 spindle carriers...??? aluminum replacements are 10 and 12 degree....thanks.
You mean how many degrees of CASTER? Stock is 10 degrees. There's no incline in the stock parts, only the inclined parts.
JAMMINKRAZY is offline
Old 01-20-2011 | 07:56 PM
  #11031
alexrckid's Avatar
ok...thanks, jammin....see ya at motorama
alexrckid is offline
Old 01-21-2011 | 08:40 AM
  #11032
Integra's Avatar
Incorrect. 1/10 is just so light of a load the shafts dont wear as noticeably.
Some feel uni's are better, Some feel CV's are better. Its all personal opinion.
Integra is offline
Old 01-21-2011 | 09:29 AM
  #11033
jmackani's Avatar
I am wondering if the uni's will have less wear going into the front of the center diff.
jmackani is offline
Old 01-21-2011 | 10:21 AM
  #11034
rider313's Avatar
I am going to give em a shot. whats the worst that can happen for $25.
rider313 is offline
Old 01-21-2011 | 02:19 PM
  #11035
Originally Posted by siv06
Hi all,
Just swopped to Losi from Mugen - read through a lot of this thread but got a couple of questions
Servo Saver - think I'm being thick but the unwind 5.5 turns comment ? Is this from totally tightened up with the spring compressed and then unwind 5.5 turns ? - I'm used to measuring this with digi calipers in the past ?
Shock Mod - using the foam compensators what is the Mod and is it worth doing ?
Thanks in advance
Neil
On the servo saver, tighten the s/s nut all the way down and then back it off 2 1/2 turns, I put locktite on the threads so it want back off, and keep a check on it.
The shock mod it make the shocks more consistent, you can order the foam compensators from 2.0 euro buggy just check amain hobbies. You will need to drill a hole in the shock cap, not sure what drill bit size but its the size of the bleed hole on the side of the cap now. The hole is to relieve any pressure on top of the foam compensator and bladder. I drilled the hole next to the mount, or you can buy the 2.0 euro buggy shock caps.
Check youtube Adam Drake has a video on the shock mod
miket is offline
Old 01-21-2011 | 03:35 PM
  #11036
bigjayjay1's Avatar
I have this funny feeling a new truggy or buggy is coming out.
Old 01-21-2011 | 03:37 PM
  #11037
deadmancourt's Avatar
nope....adam drake is still winning with his 2.0...i just talked to him on saturday at the AIRTRONICS WINTER NATIONALS
deadmancourt is offline
Old 01-21-2011 | 03:57 PM
  #11038
what makes ya think that.
Old 01-21-2011 | 04:13 PM
  #11039
dnebout's Avatar
Maybe there is, but what can they possibly do to the 2.0T roller that we haven't already done. Inclined spindles, drilled shock caps with foams, V2 tower, bigger rear hub bearings and aluminum rear diff inserts. I just can't think of anything else right now, but that's all they would do i would imagine.
If it was my company, I would come out with the 2.5T make the changes and market the truck as improved without the cost of a whole new platform for 2 more years. Economics 101 and Marketing 101 all rolled up in one smart business move!
dnebout is offline
Old 01-21-2011 | 04:23 PM
  #11040
i was just gonna say that...thats the only thing i would ever see coming from TLR as a NEW TRUGGY...but it would still probally end up bieng a 3.0 ...maybe not ...either way....these trucks are dialed, when you LEARN what they LIKE and DONT LIKE
