Like Tree4Likes
COMPETITION HEAT INC.
Old 01-09-2011 | 02:53 PM
  #946
Originally Posted by motomatt
New heaters will smoke for the 1st few uses ( this is normal). I seem to remember reading that in the Instructions a few months back.
What are instructions?
underway is offline
Old 01-09-2011 | 03:10 PM
  #947
aussies1129's Avatar
when you purchase the heater it comes with a small info booklet which explains all about the heater in there it mentions about the heater giving off smoke for a while then it goes away. also I wouldnt recommened anything under 5000mah 3s if you want to use the 12v model also get a low voltage monitor soldered on to stop the lipo dropping to low. I have a ttached a pic it gives off an alarm when drops below 9volts and has three different colored lights to indicated what voltage your battery is at. cheers
aussies1129 is offline
Old 01-09-2011 | 03:11 PM
  #948
vwduud's Avatar
the 12V heaters only draw about 5 amps.......................this would be 2C on a 2500mah battery. It's not like you need a lipo for an 1/8 scale e-truggy. A 3-cell 2500mah battery would give you about 6 (six) 5 minute heat cycles per charge.
How long does it take you to get up to temp?
Assuming we're trying to achieve between 180 and 200F?
Seems I read somewhere it took approx 15 minutes. Is this correct?
vwduud is offline
Old 01-09-2011 | 03:41 PM
  #949
motomatt's Avatar
15 minutes is about normal for the 120V unit. If I recall correctly, Tony stated that the 12V unit only takes about 5 minutes.
Instructions?..............It's the information that's provided with the product to inform the end user as to proper use of the said product.
I shoulda been a lawyer, right?
motomatt is offline
Old 01-09-2011 | 03:53 PM
  #950
NDHotbodies's Avatar
ya they do smoke a little, my son did'nt know that tho and thought something was burning . so grabbed the cord to pull it off the engine but the heat element stayed there hence pulling the cord out... gotta say Dad was'nt too happy that night.. one of those things you just eat it and order another.. too great of a product not to have.
NDHotbodies is offline
Old 01-09-2011 | 03:54 PM
  #951
rangerjkb's Avatar
For the 120v unit, it usually takes about 10 min to get engine up to temp. This engine warmer works very well, even in warm climates, I still use to minimize critical startup period and can tune as soon as I set car on the track.
rangerjkb is offline
Old 01-09-2011 | 04:00 PM
  #952
Stubbs's Avatar
Originally Posted by hambone
Ok, you just talked me out of buying a heater, lol.
Yes, like Eric said, what I was describing was the method used to make the 110V heater capable of coming up to the staging area if there was no power there. This would only be needed if you had the 110V version.
If you have the 12V, all you need to do is plug it into a battery....my apologies for the confusion.
Stubbs is offline
Old 01-09-2011 | 04:01 PM
  #953
motomatt's Avatar
Yup, most engine wear occurs when the engine is cold. Watching the guys that fire it up cold and revving the guts out of it to warm it makes me shudder.
Being able to tune shortly after start-up with the Comp Heat is the icing on the cake.
motomatt is offline
Old 01-09-2011 | 05:26 PM
  #954
sriley's Avatar
Not sure if I missed it somewhere. Can't I just hook it up to my starter box battery?
sriley is offline
Old 01-09-2011 | 05:34 PM
  #955
CompetitionHeat's Avatar
Sure, if you use a 3S lipo to power your starter box. Most put a dedicated 3S lipo in their box just for the Comp Heater though.
CompetitionHeat is offline
Old 01-09-2011 | 05:40 PM
  #956
sriley's Avatar
It has to be a lipo. The battery that is in my starter box is 12 volts. Would a car battery?
sriley is offline
Old 01-09-2011 | 05:41 PM
  #957
vwduud's Avatar
From the instruction manual, concerning "12 Volts":
"The 12 volt Comp Heater should only be powered from an 11.1v 3S Lipo battery, a 12v gel cell or car battery, or 12v power supply. Check power output and make sure it does not exceed 12V. When charging batteries only charge to 12V.
CAUTION: Some 12V power supplies produce a higher voltage. This will damage the heating element. Make sure maximum output does not exceed 12 volts.
WARNING: Do not use a power source higher than 12 volts.
Make sure your batteries are properly charged and balanced if using a Lipo battery. Follow all manufacturers’ warnings and directions.
We recommend using an 11.1v Lipo battery. Place battery inside your starter box separate from the battery used to power your starter box."
My starter battery peaks at 14.70 volts. Most "12 Volt" batteries have a higher voltage than "12 Volts".
Seems the confusion comes in from the label we've associated with batteries used to power our hobby needs and in the automotive world. While they are indeed "12 Volts", they often have peak and residual voltages well higher than 12 Volts.
vwduud is offline
Old 01-09-2011 | 05:44 PM
  #958
sriley's Avatar
Okay now I understand. Thanks vwduud.
sriley is offline
Old 01-09-2011 | 05:50 PM
  #959
+1
Then they wonder why it only lasted a couple of gallons.
Old 01-09-2011 | 05:52 PM
  #960
No problem Stubbs... I understood what you were saying.
