hitec x4
Hitec is more expensive but it does 6amps vs Quattro's 5 amps. Both are 4 channel 50watts per channel chargers. The T6 is a single type charger 5amps max with 50watts. Its like one channel of the Quattro.
More discussion on the quad type chargers here -
http://www.rcgroups.com/forums/showt...hlight=quattro
There's not been a lot of feedback on the T6.
The Hitec has a max charge rate of 6amps vs the others of just 5amps....otherwise, they appear to be the same.
http://www.troybuiltmodels.com/items/HSCHARGER.html
My bad, but the ones out on the market 1st were listed as just 5amps for max charge rate. I can find old posts on RCG that reflect that.
Now they put this somewhat confusing statement on them instead of listing a max charge rate - "50watts, current is regulated accordingly - eg. 11.1V battery: charge current approx. 4.5A, 22.2 V battery: charge current approx. 2.2A"
If you plug in a 1S, what kind of current will it actually charge at? 13.5a?
Hitec says it will charge at 6amps, so yes, with 45amps, you should have plenty to charge 2 lipos at 5.6amps with the Hitec x4 charger. Thats under the 50watts pre port output power limit (5.6a x 8.4v = 47watts).
