AXE ROSSI Engine thread.....
#301
I am looking at these two engines for my MBX-6T for next year.
Axe Rossi Cobra .25
Axe Rossi Cobra X2
What would be the pros and con’s of each?
I ran s modified gx-7r Last year I have a light trigger finger not one to keep hitting on and off through the turns.
I have seen how well the other engines run but like to go with an AXE engine. Not sure about having it modified yet.
Any Info would be great, Thanks.
Axe Rossi Cobra .25
Axe Rossi Cobra X2
I have ran the X2 for a full year now and its a GREAT motor with a TON of power and its all so good on fuel i get about 8-9 min on a Big out door track.
The Pro to the X2 its a Smooth motor makes GREAT Power.
The Con to the X2 is its a Little Soft on the bottom end i like a little more punch on the bottom.
The Pro to the Cobra 25 its a MONSTER TON of power.
The Con to the Cobra 25 its not as good on fuel as the .21 motors.
I have sold the X2 and the Cobra .25 to guys and most guys running Truggy Like the Cobra .25 better. You can get a Fuel Mod done to the Cobra .25 and it will get all most as good of fuel time as the Cobra .21 and has MONSTER POWER.
I hope i have helped and if you would like a price on a X2 are Cobra .25 just send me a PM and i will send you a price on the X2 and the Cobra .25 THANKS.
#302
I am getting my first engine. I am looking at the Mamba X1 Evolution Competition Off-Road Engine w/EFRA 2050 Tuned Pipe from Amain.
I see that the throttle arm is on the opposite direction compared to my RTR engine. Is it possible to rotate the carb? How is the carb fixed on the case?
If not how to modify throttle linkage?
I see the carb has a metal body. What are the advantages or disadvantages of a metal body compared to a plastic body like in some Novarossi?
#303
The Carb has a Plastic Sleeve that goes between the Carb and the Motor to keep it from Heat Soaking and helps it seal off better.
Just read back a couple of Pages and you can see wear i helped a guy get a motor sent back to Axe Rossi to have Warranty work done to it if you get one from Amain and something goes wrong with it i am suer you will not get that kind of help from them.
If you would like a Price just send me a PM and i will get you a Price for Motor & Pipe.
#305
Hey Guys, here are a few shots of an Axe Rossi .21 Cobra I did for a gentleman. In fact it is the same gentleman I did the .25 that I posted pics for earlier in this thread. What I did this time is because the check was a completed circle, I bladed it as far as I could to give it even more bladed surface area and now it will act even more like a single stage compressor wheel. A few shots of the sleeve to round it out. Let me know if anyone has any Axe engines that need some help
Axe Rossi Cobra .25
Axe Rossi Cobra X2
Axe Rossi Cobra .25
Axe Rossi Cobra X2
#306
What's the gain and how does it work when you blade the crank?
#307
Most of the time i don't Mod motors but i had to try one and see how it was and i like the work Mark dose and this motor ran GREAT after the Mod so give Mark Try.
#308
An engine that is timed, piped and tuned correctly has the ability to make more usuable horsepower across the board while getting a noticable gain in runtime because if the engine can scavage better, it runs cooler, tunes easier and wastes alot less fuel. Engines that are using too short of a pipe will have to be run alot richer due to the pulse returning too soon and pushing the fresh charge back down into the case so naturally the engine needs alot more fuel in the mixture to compensate for the expelled gases being reintroduced back into the cylinder. Those returning gases bring heat which raises the internal chamber temp which in turn raises overall running temp and the only way to control that is by richening up the mixture which results in reduced performance all around and wasted fuel. A pipe that is too does the opposite but requires the same adjustments which will give similar results.
The pulse in a pipe that is too long takes too long to return to create that invisible barrier at the exhaust port to hold the charge in the chamber until the port seals creating a lean condition. The incoming charge short circuits and exits the exhaust port with little to no resistance and when the pulse finally does arrive at the ports opening, some of the fresh charge burns in the pipe creating additional heat which in turn becomes an increase in running temps and once again, a richer mixture is needed to control temps and again the engine loses performance and efficiency.
There has been alot of debate if whether or not what I do with the crank actually works and I can confirm it does work and works well. The only real drawback to it all is because of the added case pressure, comes added fuel signal which will make the engine more needle sensative and depending on how well the overall carb and engine design will determine how the engine reacts. I have had engine from name brands that tuned easy and held a great tune most of its life and I have had cheap bottom feeder engines that were a nightmare from start to finish but those same engines were nightmares in stock trim as well so it goes without saying.
The turbo crank mod package is something I recommend to people who are drag racing or speed running. I have run turbo cranks in my offroad setups but most of the time they are overkill. The full race packages I offer are definately a great way to go as they offer an nice overall increase in power and runtime while keeping a nice linear feel and good tunability.
#309
THANKS Mark that should help some of the guys asking me about Mod work on Axe Rossi motors. All i know is Mark takes an Axe Rossi that runs great and has a Ton of power and makes it even better.
#311
Just as it says in the Paper work that comes with the Motor.
Kyosho17 www.kcengines.com
and I offer a Motor Brake in for New guys are guys that just don't have time PM me and i will get you a Price for the brake in if you would like use to do it. THANKS
