AXE ROSSI Engine thread.....
Old 10-26-2010 | 02:43 PM
  #271
i would like too add that this sytem is no cheap method ITS NOT A CLAMP that some may use !
kyosho17 is offline
Old 10-26-2010 | 06:36 PM
  #272
jackhammer's Avatar
Default black monster .25
anyone know if the cobra .25 p/s/r will fit and place to get and price thanks
jackhammer is offline
Old 10-27-2010 | 02:58 AM
  #273
I can get you cobra 25 p/s/r for 180 bucks weather it fits I don't know I need to do some more reseach on that they say the mamba p/s/r will fit I can get you ethier one. For the same price listed above if you would like me too send you one let me know I would be glad too help I will soon have website with everything there but for now juyou can contact me on here thanks
kyosho17 is offline
Old 10-27-2010 | 03:55 AM
  #274
jackhammer's Avatar
There is a mamba .25
Old 10-27-2010 | 08:08 AM
  #275
Iam sorry no there's not a mamba 25 I was thinkin blackmagic 21
kyosho17 is offline
Old 10-27-2010 | 02:47 PM
  #276
jackhammer's Avatar
That's ok ,any one have specs on cobra .25 sleeve outer diameter . I think they are the same . Have a monster .25 got off of juskirc year or so ago and want to rebuild
Old 10-27-2010 | 04:03 PM
  #277
I can tell u that the bore on the 25 sleeve is 17 mm
kyosho17 is offline
Old 10-28-2010 | 07:44 AM
  #278
Default Cobra X2
I have a cobra X2 In a XB808. Love the engine. Temps constantly run around 280 degrees. This seems to be where it wants to run with out bogging rich or lean. Thoughts????
wrayth is offline
Old 10-29-2010 | 09:49 AM
  #279
blackmagic21's Avatar
Talking AXE ROSSI
ALL THE AXE ENGINES I RUN TEMP AROUND THE SAME THEY SEAM TO RUN VERY WELL 270 -290 F
HOUR LONG MAINS I HAVE CAME IN AT 300-305 F AND THE ENGINE IS STILL READY TO GO FOR MORE
BLACK MAGIC .21 THE BEST ENGINE I HAVE RUN.
blackmagic21 is offline
Old 10-30-2010 | 07:41 AM
  #280
Thats the temp mine wants to run at. It's a beast at 290
wrayth is offline
Old 10-30-2010 | 07:42 AM
  #281
Default Oil COntent in fuel
Any recommendations for fuel. What oil content to help with temps but not burn it up.
wrayth is offline
Old 10-30-2010 | 05:40 PM
  #282
thenova70ss's Avatar
R/C Tech Elite Member
Cold Fusion 30% Majic is the BEST fuel you can Buy. I have been running it with my Axe Rossi motors for 3 years now and Just Love the fuel.
We have like 10 guys around me running the fuel now a lot of the guys came over from Bryon's and pay the same price for Cold Fusion so that tell you its a better fuel when some one pays the same price.
thenova70ss is offline
Old 10-31-2010 | 05:55 PM
  #283
Yea coldfusion 30% is good when I started with coldfusion I noticed lower temps and more consistency in the tuning with the engine
kyosho17 is offline
Old 11-04-2010 | 08:25 AM
  #284
Redvet79's Avatar
I don't know what this is but thought someone might want to look at it.
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT
Redvet79 is offline
Old 11-05-2010 | 09:14 PM
  #285
Default Broken rods
Axe Rossi motors have fallen out of favour in Australia due to them constantly flogging the bottom bush out of the rods. I have personnely had 2 fail and have seen at least 10 others. It has got to the stage in Australia now that you can pick up a cobra evo for $229 at Ultrahobbies as no one will buy them. Unfortunately the new updated rods seem to be failing just as much as the old rods. They fail in all motors but if you have a .25 cobra it is a given that you want make the 7 litre mark before it fails. I love the motors and still run them but not with the axe rod. I use the nova rod or a go tech rod in them and they don't have the issue.
What we have noticed is that the machining of the tapper on the intake side of the lower bush to allow it to slide over the crank pin is the issue. If you look at the tapper on the rod you will notice that the machining of the tapper is never poor and you can actually see 4 machine marks on the face of the tapper. These have an associated step in the material and over time these lines/ridge develope into fatigue cracks and the bush brakes appart.
What i have tried in an old .25 cobra is to take a tappered grinding bit and manually grind down this poor machining to remove the ridges and hopefully solve the problem.
Don't get me wrong i love the engines and will continue to run them but not with the axe rods in them. If signs of the probems are flame outs and poor idle if you are haveing these problems pop the back cover of and check the bush.
Good luck.
chalkie is offline
