os cvr .12 rebuild question >
Old 04-18-2004 | 09:29 PM
I hope that someone can help me. I am doing a rebuild on my os cvr. One of the things that needs replacing is the bearings. I had no trouble at all pulling the outside bearing out. The inside, however, has resisted my every effort to remove it. In that the bearing is the same diameter as the shaft how do I do this.
Racin Rev is offline
Old 04-19-2004 | 12:28 PM
orangbaligila's Avatar
heat it in an oven (not microwave),... then separate while still hot
orangbaligila is offline
Old 04-19-2004 | 02:05 PM
bballer's Avatar
yeah, just make sure you don't burn yourself
bballer is offline
Old 04-19-2004 | 04:30 PM
How hot and what do i use to grab it.
Old 04-22-2004 | 09:36 PM
Bud
250-300 f use an oven mit or a pair of welding gloves to hold it. once it's hot rap the back of the block down on a piece of wood. when you lift the motor back up the bearing should be laying there on the piece of wood looking at you.
Bud is offline
Old 04-22-2004 | 11:16 PM
You may wanna check out RB Concept's website, they have pretty good instructions on how to change the engine bearings.
RB Concept
Hope this helps....cheers
Devil666 is offline
Old 04-23-2004 | 01:10 AM
InitialD's Avatar
Tech Prophet
RB Concept
I don't think the instructions are there anymore after the revamp their website...
InitialD is offline
Old 04-23-2004 | 01:14 AM
spawn's Avatar
it still there... http://www.rbproducts.com/index.php?L=En
look under service, FAQ.
spawn is offline
Old 04-23-2004 | 01:18 AM
InitialD's Avatar
Tech Prophet
Thanks. You're my saviour !
InitialD is offline
Old 04-23-2004 | 08:07 PM
have you tried this and does it work that easily?
I wonder what #6 on a hot plate translates to in an oven (gas not electric.)
