Old 04-18-2004, 10:29 PM   #1
os cvr .12 rebuild question
I hope that someone can help me. I am doing a rebuild on my os cvr. One of the things that needs replacing is the bearings. I had no trouble at all pulling the outside bearing out. The inside, however, has resisted my every effort to remove it. In that the bearing is the same diameter as the shaft how do I do this.
Racin Rev is offline   Reply With Quote
Old 04-19-2004, 01:28 PM   #2
orangbaligila's Avatar
Send a message via Yahoo to orangbaligila
heat it in an oven (not microwave),... then separate while still hot
HPI Racing Bali
Team HB Bali
orangbaligila is offline   Reply With Quote
Old 04-19-2004, 03:05 PM   #3
bballer's Avatar
yeah, just make sure you don't burn yourself
bballer is offline   Reply With Quote
Old 04-19-2004, 05:30 PM   #4
How hot and what do i use to grab it.
Old 04-22-2004, 10:36 PM   #5
Bud
250-300 f use an oven mit or a pair of welding gloves to hold it. once it's hot rap the back of the block down on a piece of wood. when you lift the motor back up the bearing should be laying there on the piece of wood looking at you.
Bud is offline   Reply With Quote
Old 04-23-2004, 12:16 AM   #6
You may wanna check out RB Concept's website, they have pretty good instructions on how to change the engine bearings.
RB Concept
Hope this helps....cheers
Devil666 is offline   Reply With Quote
Old 04-23-2004, 02:10 AM   #7
InitialD's Avatar
RB Concept
I don't think the instructions are there anymore after the revamp their website...
Old 04-23-2004, 02:14 AM   #8
spawn's Avatar
it still there... http://www.rbproducts.com/index.php?L=En
look under service, FAQ.
spawn is offline   Reply With Quote
Old 04-23-2004, 02:18 AM   #9
InitialD's Avatar
Thanks. You're my saviour !
Old 04-23-2004, 09:07 PM   #10
have you tried this and does it work that easily?
I wonder what #6 on a hot plate translates to in an oven (gas not electric.)
Servo Rebuild Question butrflynlambie Radio and Electronics 0 02-27-2008 05:26 PM
Stupid rebuild question lotus1 Nitro On-Road 4 09-25-2007 06:57 AM
WTB shock rebuild kit fenix R/C Items: Wanted to Buy 0 08-25-2006 03:30 AM
Question Regarding OS 12 TR Rebuild Gambelli Nitro On-Road 4 08-03-2006 06:24 PM
MVP rebuild TuxRacer Electric On-Road 3 11-18-2003 09:05 AM
