Like Tree195Likes
Novarossi engines thread
Old 11-29-2010 | 11:50 AM
  #3781
Chickentrader's Avatar
Originally Posted by NitroWD
thanks Lars, but what i meant is what other brands of plugs could fit the nova engines nicely?
Oh sorry about that, I don't really know of any except for the ODonnell plugs, but I know that quite few other brands will work.
Kindest regards,
Lars.
Chickentrader is offline
Old 11-29-2010 | 11:57 AM
  #3782
DS Motorsport's Avatar
Get some Sirio based plugs, Sirio, Capricorn, Reds and more I can't remember.
I'm using the Capricorn plugs in all my Nova engines since the GRP plug quality went to crap as well (just like Nova).
The Sirio based plugs last a lot longer and make a bit more topend power compared to a nova plug.
DS Motorsport is offline
Old 11-30-2010 | 02:06 AM
  #3783
Jazza's Avatar
Default Plug Question For DS
[QUOTE=DS Motorsport;8273990]Get some Sirio based plugs,
Hi DS
I don't own a Sirio motor but I know the sirio button is a different shape (slight tapper difference) to the nova's & the bottom of the sirio & nova plugs replicate this to correspond to there respective button chamber.
With this in mind would it still be ok to use Sirio plugs in nova engines as I too need plugs & the sirio plugs are much easier for me to obtain.
Also your capricorn lab looks awesome DS
Cheers Daz
Jazza is offline
Old 11-30-2010 | 03:04 AM
  #3784
[QUOTE=Jazza;8277430]
Hi DS
Cheers Daz
Hi Daz,
I haven't seen a sirio button op close, but for my Lab engines I informed with Capricorn which plugs they recommend and they recommended the Capricorn plugs, which are Sirio plugs. So don't think there is a problem in terms of fit or taper, also the Nova button doesn't look damaged or anything.
Thanks man, for 2011 it's going to look even better.
Old 11-30-2010 | 10:49 PM
  #3785
I've got my 353ct in and ready to run, 25 degrees outside and six inches of snow on the ground.
I'm going to need a connecting rod for this motor when it drops its nuts, anybody know where I can pick one up on the west coast?
I'm very impressed with this motor and my hats off to Novarossi.
Sprint Doctor is offline
Old 12-01-2010 | 02:10 AM
  #3786
Geberit's Avatar
What's the difference between the Novarosi pipes EFRA 2660 and EFRA 2652 1/10 on-road?
Thenks
Geberit is offline
Old 12-04-2010 | 03:46 PM
  #3787
Default Crank and rod needed n12ll5
looking for a good used crank and rod or new parts
crank #15605
rod #07601
Is this max power crank the same as the ll5 it uses the same novarossi numbers?
www . rcmaxpower.com/en/products/dwn.asp?file=138.pdf
take spaces out
Kevin R is offline
Old 12-07-2010 | 05:45 PM
  #3788
Michael_T's Avatar
Thenks
I did some back to back tests with both pipes on my 353-09.
The 2660 gave better power on low, medium and top end. Overall a better pipe then the 2652.
I hear now the 2662 is an improvement over the 2660
Michael_T is online now
Old 12-09-2010 | 05:58 AM
  #3789
FF25510's Avatar
Default 35PLUS21LC/WC09
hi guys
does NR 35PLUS21LC/WC09 came with manifold
thanks in advised
FF25510 is offline
Old 12-09-2010 | 12:57 PM
  #3790
RC MARKET's Avatar
X'Mas Sale now !
RC MARKET is offline
Old 12-28-2010 | 04:00 AM
  #3791
CHRISP76's Avatar
Hey,
Was wondering if someone could please tell me what the factory mid range needle setting is for a Flash Special Tuned. Thanks in advance.
CHRISP76 is offline
Old 12-28-2010 | 05:03 AM
  #3792
The midrange needle has the same effect als the low speed needle.
The only difference is that it will move the spray nozzle within the airflow so you can tune it a bit to optimze the position of the spray nozzle at a certain opening of the carburator.
Roelof is online now
Old 12-28-2010 | 07:05 PM
  #3793
CHRISP76's Avatar
thanks but do u know where it should be set?
CHRISP76 is offline
Old 12-28-2010 | 07:11 PM
  #3794
wingracer's Avatar
Flush
wingracer is offline
Old 12-29-2010 | 02:29 AM
  #3795
CHRISP76's Avatar
Thanks mate, I appreciate it.
CHRISP76 is offline
