COMPETITION HEAT INC.
#886
Yep, I know I used it everytime on the track. My truggy engine had two tanks ran through it before this weekend, and even with the low temps, it was a breeze to fire and tune and ran flawless all week thanks to the heater. I always said that 2.4 radios and personal transponders were the top 2 things to ever hit the market, and I think this ranks in at 3rd. Almost seems like a preferred necessity at any event, warm or cold outside.
#887
Just returned from the Fall Brawl Race in Myrtle Beach. For those who have never been, I would highly recommend this event. The track is located in a very nice park and is a well kept facility with a great layout and track surface.These guys know how to run a great event and I will be back next year as a sponsor and participant.
Competition Heat engine heaters were in full swing as the temps ranged from the low 30's at night to high 40's during the day. Most competitors were using our 120V heater and a few used the new 12V along with myself. The great thing about the 120V is you could put it on and pretty much forget about it until your ready to fire it up, it sure came in handy.
As for the 12V Comp Heater, I, along with a handfull of others used it over the weekend with great success.
I was secretly / selfishly hoping that it would be cold and raining all weekend, so I didn't have to feel bad about not going, but sure looks like that didn't happen!
Oh well....hopefully the Spring race will be as much fun. I'm gonna try and get to that one. By the way, are you going to be at the PNB in March?
#888
i won't use lipo's either
#889
You guys make me laugh! LOL any 12 volt battery will work that why it is called 12 volt! Now how long do u think a battery will stay at a full charge, just charge a battery up and dont worry about it! LOL If u want to run a 12 volt Gel then run it on it! WOW
#890
In all the "recommended" texts I have read it says to set it at 11.5v..
example: "charge to 12.1V Max for optimum performance and reliability"
I'll just run it and hope it is OK. If it just gets hotter faster, thats fine by me, I'm more concerned about it lasting.
#891
just got my 12v comp heater today and it worked to perfection on a 30c 5000mah lipo, no hassle easy to use and engines fired straight up very happy with this product and the engines are happy too!
cheers
cheers
#892
Looking to get an engine heater, just not sure as to get the 120v or 12v. I don't want to have to order a 11.1v battery just for the heater and have read on here that a lead acid battery will damage the heating elements over time. Can anyone confirm that the lipo battery is the only battery to use?
http://cgi.ebay.com.au/11-1v-5000mAh...item19bda5ea8c
cheers
#894
Planning to buy one but I want the 110v version .I have no extra 80$ for battery and 150$+ for a powersuplie with regulator ...Nice and usefull product but I hope the 110v stay available .......
#896
Charlymbx5- 5 heat cycles on race day should be plenty, although before Main event time I recharge everything to make sure I'm ready to go.
Gabor Szilagyi- The 110V Comp Heater will always be available. We have no plans to discontinue, in fact our New 110V Comp Heaters come with the new cover just like the 12V.
#897
Could you please explain what do you mean by "5 heat cycles" ?
Is that heating the engine 5 times ?
During a race day i have to start the engine at least 6 times (practice, 3 quals, semi, final).
The benefit i see with the 12V version is to be able to use it when there's no 110/220V available at the track.
So it means that i will have to get 2 lipo packs.
#898
Thanks for the quick answer.
Yes, it means heating the engine 5 times in 10 minute cycles each. In really cold weather you would want to leave it on for 10 minutes, but when the weather is warm it will only need to be left on for 5 minutes giving you twice the number of heat cycles.
Most tracks in the US have power, if your local track has power then I would recommend the 110V. If you can afford to have both, then you will have the best of both worlds when it comes to pre-heating.
No need for two lipo packs, just one. I use a 3S lipo with 2100 mah in my starter box for the Comp Heater. I don't mind charging batteries and working on my equipment when at the track, it's a part of the hobby I very much enjoy.
4Likes
