Novarossi engines thread
#3766
#3768
Hi,
Just completed running in my S21WCS09.
Engine comes with C6TF plug.
I am in a country where ambient temperature is approximately 32 degree celsius year round.
Will the nova C7TGF plug be more suited given the environment I am running the engine in?
Sam
Sam
#3770
If it runs a bit too hot, then go for the C7. If where you live is pretty humid, then maybe you should stick to the 6, but if its dry, then I would go the C7.
#3771
-X-
"-9Celsius today and snowing
#3772
Have a question got this engine today. The side has a label says Flash .21 Special Factory Tuned and Break In. ????
Is it real or just a gimmick??
Does it mean i don't have to run in and just tuned and go or is there a procedure to use it.
This is my second Nova, (1st is a Flash .21 Special Factory tuned).
#3773
#3774
Kindest regards,
Lars.
#3775
the breakin version assures you that the engnie broken in correctly,you also get a data sheet card that tells you the specs of the engine,honestly this is the best version you can buy cause this assures you that your engine has no defects in the fit and its a plus that you dont have to spend the time doing it, the broken in engnies will require 500cc of fuel more and its ready to race tune it .
this version of engnie is done by the same person in Novarossi that does all the Team engines so it not a gimmick ,honestly this as close as you will get to the same engnies as the factory guys use .
#3776
Thank you now i understand better so just run 500cc of fuel like running in manner and then cool it down and start race tuning. Oh boy this will be far easier than what i use before. I be sticking to these kind of engine.
Thank you all for the kind advise.
+1 Novarossi
+1 Novarossi
#3778
It is different for different engines and running conditions. We use Nova C5TGC or C5TCH; for Novarossi 353, 3SCT or Flash 12 engines, but most of the guys around here use Nova C6TGC or C6TGH turbo plugs. Many around here believe that ODonnell plugs are better (and much cheaper), and we have also used them at times. Use ODonnell 77 to replace the Nova 5. or ODonnell 99 instead of the Nova 6. We use O.S. No 8 glow plugs for a Nova CX12 (non turbo plug head).
The information in the file attachment should help. Please note that C (calda) and H (hot) is the same in Novarossi turbo plugs.
Kindest regards,
Lars
Kindest regards,
Lars
#3779
Kindest regards,
Lars
Kindest regards,
Lars
#3780
Kindest regards,
Lars
Kindest regards,
Lars
195Likes
I notified them about there mistake. Gotta have the 353race C tuned.
